Old 03-11-2009, 07:34 AM   #1
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: GM 010/020 Blocks
TRMNATR,
Email me direct. I've got several cranks.
Terry
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 03-11-2009, 10:04 AM   #2
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
best stock small blocks. know of a few 9 second cars built before the ease of availability of good quality aftermarket blocks. friend has a few of these 010 over 020 blocks sitting. the blocks I know of took a major beating.
chris ok is offline   Reply With Quote
Old 03-11-2009, 10:29 AM   #3
trmnatr
Hi Chris,
Thanks for the information. I have not really used a ton of these blocks for race engines, a few but not at this kind of rpm
I usually use a 2 bolt main, filled with hardblok with Milodon splayed main caps (which i thought about on this one)
Being this is what i would call more of a budget build i thought about using the domed pistons which are 480gram, that would allow me to keep the 329gram pistons to save a few $ for a super light aluminum rod (about 435gram rod)
Im gonna use my Comp cam which is HXL intake lobe and RZ exhaust lobe. 307/317 @.020" 278/284 @.050" 201/197 @.200" .726"/.660" with 1.6/1.5 rockers 106 degree lobe seperation
Top View
Skirt View
Underside View
trmnatr is offline   Reply With Quote
Old 03-11-2009, 10:31 AM   #4
trmnatr
Originally Posted by Terry Cain View Post
TRMNATR,
Terry
Terry,
Thanks, message sent
