Old 01-07-2009, 11:57 PM   #1
SSDiv6
Default WJ & Kurt Sitting Out for 2009 ???
http://www.competitionplus.com/index...=8900&Itemid=6
Old 01-08-2009, 12:02 AM   #2
trmnatr
Default Re: WJ & Kurt Sitting Out for 2009 ???
I like 4 drivers in Pro Stock really well and thats 2 of them
If the Pro racers didnt turn the class into multi million dollar programs, Which started in the late 70's to early 80's, all the racers today like WJ and KJ could afford to compete
Like my buddy said about the pro racers wanting this big $$ class,, Be carefull what you ask for, you might just get it !!!!!! It took some years but now we are here were they cant run in what they made,,,,
In My Opinion, i hope WJ and KJ get a sponsor but it probally wont happen
trmnatr is offline   Reply With Quote
Old 01-08-2009, 08:08 AM   #3
Detroit Bob
Liked 8 Times in 3 Posts
Boy are you right, they have turned pro stock into a mega bucks deal with electronic shocks and all, they deserve what they get. All three of those pro classes are out of control and now the grim reaper is at their door.
Bob Kowal STK 345
Detroit Bob is offline   Reply With Quote
Old 01-08-2009, 09:38 AM   #4
STEVEN NOVOSEL
Liked 12 Times in 6 Posts
Thumbs up Re: WJ & Kurt Sitting Out for 2009 ???
Hopefully Delco will stay with KJ.......Rumor I have heard is that the Professor may race a "Brown Truck"
STEVEN NOVOSEL is offline   Reply With Quote
Old 01-08-2009, 10:13 AM   #5
Chad Rhodes
i would think at this point that info would be out, but i hope you're right
Chad Rhodes 2113 I/SA
Old 01-08-2009, 10:19 AM   #6
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
If all the pro category racers start suffering from the same fate of cutbacks and lack of funding will the NHRA put its racing on hold? I mean who will be left to pull in the fans?
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
Old 01-08-2009, 01:16 PM   #7
Chad Rhodes
Originally Posted by Steve Polhill View Post
With some added rules NHRA coupld make Pro Stock a cheaper class to run.. it would most likely maske it slower but.
yes they could, but they would never take a step backwards
Old 01-08-2009, 01:56 PM   #8
tim worner
Liked 126 Times in 20 Posts
Maybe NHRA will realise the sportman shows are pretty good and promote them a little bit more. Several years ago the National Dragster did a servey on the most popular eliminator 1st was Funnt Car 2nd was Super Stock. Never heard much about it after that.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 01-08-2009, 03:13 PM   #9
trmnatr
I feel NHRA Pro Stock should have an affordable Pro Stock class such as the following rules,,,
- N/A
- Any compression up to say 13.5:1
- Any engine that uses a factory stroke, can be factory block or aftermarket
- Must be 23 degree heads
- Any Automatic (no more than 3 gears unless factory equipped), any manual up to 5 speeds
- Any rear
- Any suspension
Basically a Super Stock class where any 23 degree head can be used, any compression, any rods and that would be a Pro Stock class but make it where the engines have to be as follows (GM for example)
- 283, 302, 305, 307, 327, 350, 400, 396, 427, 454
Cant be strokers
That would put alot of bracket racers in competition with a 427 etc in their car,,,,,,,,,
Classes should be run in an index if needed
Min race weight for example,, 3200 pounds for small block cars and 3400 for big block cars
Old 01-08-2009, 03:19 PM   #10
Chad Rhodes
- N/A
- Any rear
- Any suspension
Cant be strokers
they already have that, its called SS/xM or Comp
