Old 01-08-2009, 03:13 PM   #9
trmnatr
Default Re: WJ & Kurt Sitting Out for 2009 ???
Originally Posted by tim worner View Post
Maybe NHRA will realise the sportman shows are pretty good and promote them a little bit more. Several years ago the National Dragster did a servey on the most popular eliminator 1st was Funnt Car 2nd was Super Stock. Never heard much about it after that.
I feel NHRA Pro Stock should have an affordable Pro Stock class such as the following rules,,,
- N/A
- Any compression up to say 13.5:1
- Any engine that uses a factory stroke, can be factory block or aftermarket
- Must be 23 degree heads
- Any Automatic (no more than 3 gears unless factory equipped), any manual up to 5 speeds
- Any rear
- Any suspension
Basically a Super Stock class where any 23 degree head can be used, any compression, any rods and that would be a Pro Stock class but make it where the engines have to be as follows (GM for example)
- 283, 302, 305, 307, 327, 350, 400, 396, 427, 454
Cant be strokers
That would put alot of bracket racers in competition with a 427 etc in their car,,,,,,,,,
Classes should be run in an index if needed
Min race weight for example,, 3200 pounds for small block cars and 3400 for big block cars
trmnatr is offline   Reply With Quote
