Old 08-27-2008, 08:42 PM   #1
pro7474
Liked 3 Times in 1 Post
Question Win Class Loose Class Go Home
Let me see if I understand this with the new rules, You go to Indy and run a Class in either SS or Stock that has only 1 car, so durning class eliminations you run .900 under but because the bump is .910 you do not quailfy. So according to the new rules if there is only 1 car in eliminations you must not only run .500 under the index but you must also stage 1st round under your own power. So seeing as you cannot stage under your own power if you do not qualify you do not win class and get no trophy or money.
Chris lamb
pro7474 is offline   Reply With Quote
