Old 09-27-2021, 03:19 PM   #51
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default Re: Project - NHRA Stock and S/S results 61-68
IIRC, I have evidence of Truman Field's '68 Birds running A/S, B/S, C/S, D/S, Plus B Pure Stock.
Don't know what engine he was running, or the exact year of every pic.
I assume he at least experimented with the 330hp D-port, at some point. OR, maybe not. Don't know.
The different classes may just reflect rule, classification, & hp factor changes, in different years.
Name:	1 - '72 A-S Class Win .jpg
ID:	60124   Click image for larger version
Name:	2 - A-S .jpg
ID:	60125   Click image for larger version
Name:	3 - B-S Rec '77 .jpg
Name:	4 - B Pure Stock .jpg
ID:	60127   Click image for larger version
Name:	5 - Indy Win '73 .jpg
ID:	60128   Click image for larger version
Name:	6 - '77 C-S Class Win .jpg
Name:	7 - '71 D-S Class Win .jpg
ID:	60130   Click image for larger version
Name:	8 - D-S Later Years .jpg
Old 09-29-2021, 03:22 AM   #52
Rat Patrol
Rat Patrol's Avatar
Liked 32 Times in 27 Posts
I agree with you both - I think its pretty conclusive that the 69 Spring B/SA winner was W olf & Mclelland.
Ray McClelland won A/Stock Auto at the 68 SpringNats in a 62 Cat...so the class drop makes sense.
Re - Joe Dougherty - I have a pic showing he ran a 150 Delivery, not a Wagon.
Rat Patrol is offline   Reply With Quote
Old 09-29-2021, 03:36 AM   #53
Rat Patrol
Rat Patrol's Avatar
Originally Posted by DeuceCoupe View Post
In learning this the Kister Big Iron story is another I've tried to follow.
His 1960 389/363hp Super Duty car, followed by a 400/370hp (factored to 380hp) RamAir4 69 GTO, and then a "base" 400/350hp 70 GTO, all with national wins/records.
Kister was runner-up in D/S=9.00 class here at 69 Indy. The narrative I have says Robertson won D/S, but in a 69 Buick and no Buick will fit that class. So I guessed Robertson ran either a RamAir4 or a Z28.
Then from this picture out of Petersen, found with the help of another Class Racer, I concluded this was probably the D/S race where probably Robertson in the Z28 won against runner-up Kister in the 69 RamAir4
https://archive.petersen.org/pages/p...php?ref=320033
DC - Your 69 Indy list has a Z28 winning E/Stock (Durbin)....so not sure how one could also win D/Stock?
Sorry if that sends you back to the drawing board....
Old 09-29-2021, 04:44 AM   #54
Rat Patrol
Rat Patrol's Avatar
Davisson won D/SA atthe 69 winters in a 62 Pontiac
McClelland ran the 383cui/333hp Tempest 4V motor in D/Stock Auto
Max Sterling ran the same combo in D/Stock
....both at 69 SpringNats
What combo would Wolf have run in B/SA at the 69 SpringNats? I’m guessing it was the 68 A/SA Springnats car - which was a 421/405 , like the pic Old School posted.
Old 09-29-2021, 08:22 AM   #55
DeuceCoupe
Liked 48 Times in 44 Posts
Well we can say that 69 Spring B/SA=8.00 was Wolf of Wolf McClelland, but not in their usual 62 SuperDuty 421. It doesnt fit the class.
McClelland won 68 Spring C/SA=9.00 class in the big SuperDuty Cat.
That same class became D/SA=9.00 for 69 Spring, which he won in the same car.
It could well be that Wolf won B/SA=8.00 in Spring 68, but I'm still not sure which car - a highly factored RA4? That's about all that makes sense.
Agree on Dougherty - I just put wagon because Boyce'e text says that. But on the same pg116 he shows a picture of the Sedan Delivery, which was the usual entry down there until the big truck transmission was banned for the 1970 season. It's actually a better fit to class anyway.
Old 09-29-2021, 08:27 AM   #56
DeuceCoupe
Oh that's an easier one. For THAT YEAR, factored to 320hp,
67 Z28 = 9.23 fits D/S=9.00
68 Z28 = 9.59 fits E/S=9.50
69 Z28 = 10.05 fits F/S=10.00 but didnt win that class
I've heard 428CJ guys complain about having to run against the little toy Z28 cars. Well, the early Camaros were just LIGHT - and the Z28 had a monster cam, and a bigger carb than the 428CJ, so they made some power.
Old 09-29-2021, 09:12 AM   #57
DeuceCoupe
OK wait:
I have Davisson winning 69 Winter D/S=9.00 in a 62 Cat 421SD.
McClelland in 69 Spring D/SA=9.00, also 62 Cat 421SD
Sterling in 69 Spring D/S=9.00, again 62 Cat 421SD
The 61 Cat/Ventura 389/333hp has a W/P of just over 11, which would run way down in H/SA=11.00 class in 1969.
The Wolf car 69 Spring B/SA=8.00 could not be a 62 Cat 421SD - those cars are just too heavy.
The lightest aluminum 62 421 SuperDuty Cat I see is the aluminum front 2-door sedan at
3609/405=8.91 which would run in C/SA=8.50 but a bad fit.
The big 421SD always ran at W/P=9.01 from 1968-up which would be D/S=9.00 or D/SA=9.00 in 1969.
A 63 Swiss Cheese Cat could run up in B/SA=8.00 but those were never stock legal - not enough made.
Old 09-29-2021, 03:43 PM   #58
oldskool
oldskool's Avatar
"...The 61 Cat/Ventura 389/333hp has a W/P of just over 11, which would run way down in H/SA=11.00 class in 1969..."
Don't know about the exact math. But that sounds reasonable.
Below is a pic of the Moore '61 368hp car. Caption says it set the F/S record in '69. So, if that caption is correct, then with a 333hp engine, it would have to run a lower class than F.
Name:	1 - 368hp '61 .jpg
Old 09-29-2021, 04:12 PM   #59
DeuceCoupe
That sounds right.
3683/368=10.01 top of F/S=10.00 class
3683/333=11.05 top of H/S=11.05 (or H/SA if trans weight is ignored)
What I CANT find right now is where the 333hp car won or set a record.
But for sure, that combo is not way up there in the B/SA=8.00 class or even D/SA=9.00 class in 1969.
Old 09-29-2021, 05:15 PM   #60
oldskool
oldskool's Avatar
"...What combo would Wolf have run in B/SA at the 69 SpringNats?..."
If it wasn't a 421SD powered car, I'd say it had to either be a Tri-Power GTO, or a round port Bird.
Those are the only non-421SD cars I remember seeing pics of, running in B. Even have a pic of Truman Fields' '68 Bird running in A/S. Pretty sure he set records in both B/S & C/S.
Don't know exactly what years he ran in which classes. But, apparently, round port '68 Birds ran B/S the first few years after they came out. Here are some pics. Mike McKinney was running B/S when he won Indy '77, in Truman's first Bird. That same year, Truman set the B/S record in the Bird he'd took on trade, from Mike. Also got the C/S Indy class win that year. Don't know what changes were made to switch from B/S to C/S, back then. Were you allowed to remove & add weight, in '77 ?
Name:	1 - Weidner '68 .jpg
ID:	60198   Click image for larger version
Name:	2 - B-SA .jpg
ID:	60199   Click image for larger version
Name:	3 - B-S '68 .jpg
Name:	4 - B-S Record .jpg
ID:	60201   Click image for larger version
Name:	5 - McKinney B-S .jpg
ID:	60202   Click image for larger version
