#1 | |
That all mighty 300/315 is actually facotred to 327 HP now. Damn, If I had a little more money I might be able to compete heads up with the 350 Camaro's that run in SS/HA and SS/IA. Now if they only do something with those 327's that are hauling a#$. Smitty |
Liked 1,583 Times in 582 Posts
John...Smitty did not say he did not work hard on his combo...he was talking about if he had more money to spend in the car. There is a big difference in the availability and cost of Chevy parts versus a Ford Cleveland engine.
#4 | |
My point is this, those combos are killer, they continulely dominate classes and the way the rules are set they should be factored, that is all I am saying. Thanks for the motivation however to work on my combo because that is what we plan to do. |
#5 | |
Liked 2 Times in 2 Posts
Under what reasoning? When you compare the Chevy engine, with a lower deck block, lighter rotating assembly, better parts availability, the advantage is for the Chevy. Do not justify the Cleveland advantage on the cylinder head ports and valve size only.
