Liked 2 Times in 1 Post
We are trying to get a car set up this year and having a lot of difficulty with traction. 69 Camaro, 427, Jerico. Working with Calvert to ensure that was all correct and they said the tires are shot (20 runs) and to get a stiffer sidewall and harder compound. Tires are Hoosier 29x9 D06
I don't see any stiff sidewall tires in 9 inch on the Hoosier site. Mickey Thompson has a 29.5x9 (3056ST) which says it is recommended for manual transmissions. The MT site also calls out a different stiff sidewall tire for cars over 3,000 lbs (3360), but do not have it in a 9" tire. What are others running for tires with a stick? |
The guys I would ask are Brett McFarland, Ed Bednaz and Bob Broadbent.
Liked 509 Times in 117 Posts
Best tire I've found for best traction and longevity is the Hoosier 18200 30x9 D07. Usually get 80-100 runs before they go away. I've run the M/T tire and as far as I'm concerned they're not a good tire as I could never get more than 25 runs on then. Clutch settings and shock settings are also a factor plus tire pressure and launch RPM. A racepak can't hurt as well.
68 Chevy11 327 F/S |
Liked 27 Times in 10 Posts
hendersonraceshop.com Talk to Troy.
