Old 06-05-2025, 06:02 PM   #51
Liked 5,113 Times in 1,948 Posts
Default Re: Coming Soon.....
Originally Posted by L.Fite View Post
So... when do '69 Camaros get rollers and a 9"...?
Asking for a friend...
Never. Same goes for an aluminum center section in a 69 Mustang.
Just old "junk" to them.
Although you guys pay in a bunch of money for entries. They don't care though.
I wonder how much this shakedown is worth?
Old 06-05-2025, 07:56 PM   #52
Wayne Scraba
Liked 186 Times in 48 Posts
Smile Re: Coming Soon.....
Most likely inevitable. In a way I kind of like the car.
Lets play a game: Guess the shipping weight and NHRA horsepower
Im in at 2900 pounds and 325 hp?
Wayne Scraba is offline   Reply With Quote
Old 06-05-2025, 09:54 PM   #53
Mike Schwartz
Liked 248 Times in 89 Posts
Something seperate from the car itself:
Is this the same situation Chevy, Ford, and Dodge are in this decade+? With only a single High Performance model or a Factory Package in the Classification Guide? With no "normal" cars from those Makes?
Old 06-05-2025, 10:19 PM   #54
SSDiv6
Liked 1,575 Times in 580 Posts
Originally Posted by MoJo Risen View Post
Has anybody even tried the Turbo 180 mail truck transmission?
I guess this means the cobrajets can run a turbo 200, right?
Well...they already run the TH-400 and Powerglide.
Due to the weight and torque, I do not think a TH-200 will live in an FS car.
Old 06-05-2025, 10:34 PM   #55
SSDiv6
Originally Posted by Rory McNeil View Post
Unless the rules have changed, how does a General Motors automatic transmission bolt up to a Toyota (or BMW) engine, and even more curious, how does a Japanese car get around that pesky rule that has always required the transmission (and rearend) being used, to be of the same manufacturer as the car? Or did Toyota buy GM while nobody was looking? I really doubt that this so called "Production" Toyota car is available at the Toyota dealership with a GM Turbo 400 transmission connecting the engine to the , I assume, Toyota rear axle assembly.
Rory,
It is the same situation when cars that were available with a Powerglide only, were allowed to run a 3-speed auto. In the case of this car, it is available with a GM transmission from the factory. Therefore, they are applying the same rule as allowing to run a TH-200 in lieu of the OEM TH-350 or TH-400. Even if GUMP ran the OEM GM transmission, there are already parts such as high performance valve bodies and torque converters in the market. Also, Sonnax and TransGo make high performance internal components for the OEM transmission.
Old 06-05-2025, 10:49 PM   #56
TommyPettigrew3076
Liked 26 Times in 11 Posts
why would you even want a 9 inch ? aside from some gear ratio options and ease to swap center section there is no performance advantage other then maybe the gear option ratios offered but I doubt much if any . Further more from what I understand the 12 bolt has less reciprocating weight( I don't know that for a fact ) but I did read somewhere some of the fast Hemi Cars has 12 bolts in them if I recall I could be wrong .
TommyPettigrew3076 is offline   Reply With Quote
Old 06-05-2025, 10:57 PM   #57
Rory McNeil
Liked 1,102 Times in 301 Posts
Rory,
Joe, and when when NHRA decided to allow 3 speed automatics to replace the 2 speed Powerglide, the 3 speeds allowed were required to be of the same manufacturer, and directly bolt to the engine. Last I checked, (and I was a Toyota dealership tech for 24 years before I retired), and although we did have a Subaru powered model, none of cars or trucks came with GM built transmissions. I wonder how much $$$ Toyota had to slide across the table at the NHRA office, to get this car, which is looking more like a Factory GT/"Paper Tiger" car, into the NHRA Classification Guide?
NHRA 6390 STK
M/S 85 Mustang
Old 06-06-2025, 02:18 AM   #58
GUMP
Liked 2,336 Times in 549 Posts
There was actually a discussion about using a Toyota rear. The "no truck rears" got us there. I personally feel that would have been much cooler. But, the rules say a 9 inch is OK.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-06-2025, 02:20 AM   #59
GUMP
I wonder how much $$$ Toyota had to slide across the table at the NHRA office....
None.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-06-2025, 06:48 AM   #60
MR DERBY CITY
Liked 7,916 Times in 1,515 Posts
This Toyota AND the Copo,Mustang and Challenger’s would be SUPER COOL if NHRA had created an FX class instead of including them in stock eliminator.
