#21 |
Liked 127 Times in 49 Posts
I would like to see every other race with class. Bring IHRA back to the glory days where 100 cars showed up and you won't have issues with class runoffs. IHRA Top Stock and maybe Junior Stock would be awesome.
Bobby Lundholm 3516 G/SA |
#22 |
Liked 77 Times in 15 Posts
I think it depends on the schedule, lots of great posts/suggestions as they relate to the Nhra schedule. For Ihra, it depends more on track, location, and race quantity.
If IHRA offers class, we are going. We are class racers and NHRA has really diminished that part of S/SS. Also, Alan, make license cross over easy and membership easy so guys can just show up. That easy process got us to our first Ihra races 20yrs ago. |
#23 |
Liked 209 Times in 50 Posts
2- times in each division. All nitro jams. Q1 for the ladder then class runoffs. All runs count towards AHFS as the current NHRA system.
The only change needed is allow requests for hp reduction. If less then 2 triggers. -1.0 runs If average of all runs is less then -0.065. Minimum of 20 total runs Do a HP reduction. Sure there will be triggers and HP will be awarded. But with a consistent system combos can also be corrected if over adjusted. Allows everyone to race and make their decisions at the stripe. Use your existing HP ratings and run autos and sticks together for heads up. If the HP ratings are different from stock to auto spit the difference and make them the same. Simple and straightforward.
Brian Anderson 5058 B/SA 99 Chevy Camaro SS Last edited by SDmopar; 01-27-2025 at 08:01 PM. Reason: Typo |
#24 |
Liked 1,471 Times in 308 Posts
It seems this post has been modified to include AHFS and HP Ratings.
If IHRA wants to keep their life simple, which we want them to do, we don't want to become more aggravation than we're worth, then the AHFS should look like this this: over 1.25 under-3.5% Hit. Under -.50 under, of which records must be kept by individual racer and sent in at year end for verification-3.5 % reduction. No averages to keep track of, just easy peasy. No Aspirin required on either side. J.R. |
#25 |
Liked 172 Times in 46 Posts
IHRA in the south works, up here in the great white north, no tracks as of right now here it does not work. I have hopes that in the future that will change, so we will see.
Dirk
Dirk Olson 5036 STK |
#26 |
Liked 409 Times in 113 Posts
At least at 2 events per year in each division.
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
#27 | |
Main point is welcome IHRA yes we want Class eliminations and let?s simplify it so we can get more heads up runs.
Brian Anderson 5058 B/SA 99 Chevy Camaro SS |
#28 |
Liked 8,049 Times in 1,529 Posts
Back in the day, did not IHRA follow NHRA s lead regarding HP factors ?…...not sure we can use AHFS and IHRA in the same sentence. This would be the perfect time for Michael Beard to chime in ….
#29 |
IHRA has a great opportunity to learn from NHRA and make improvements. There is plenty of room for both. The racer wins when they are competing for business. More heads up races make for what we all want a true performance based class on an evolving equal playing field. Personal index?s would be great but a lot hassle
#30 |
Liked 227 Times in 74 Posts
I like the idea for a Top Stock and Junior Stock to start with. and I agree on License,Membership and car number. Make it easy to switch back and forth.
J.T. Rose & Associates U/SA T/SA 302R Last edited by Rose Racing; 01-27-2025 at 10:40 PM. |
