Old 11-11-2024, 01:33 PM   #23
Rory McNeil
Liked 1,104 Times in 302 Posts
Default Re: index lowering
Wouldn`t it be great, if before any combination got a HP hit, that the person that caused the hit, was torn down to ensure that his car was 100% legal? An across the board lowering of all the indexes would effect some combinations much more than others, not every combination is allowed to benefit from the use of "approved" aftermarket aluminum cylinder heads, aftermarket carbs, optional camshafts etc. Nor do other "enhancements" help all combinations the same, roller rocker arms, wheelie bars, lightweight racing seats, fuel cells etc, don`t help much if you are running some non mainstream low RPM, 2 barrel engine with a crappy intake manifold and cylinder heads. Some combos, like 396s, can build a "legal" Stocker engine, and not use virtually a single OE factory installed GM part in the engine. Many others can not use anything that was not used on the combination when it rolled of the assembly line. It would be nice if there was still a little bit of "stock" in Stock Eliminator.
NHRA 6390 STK
M/S 85 Mustang
