Old 10-21-2024, 08:08 AM   #1
Doug Hoven
Liked 867 Times in 165 Posts
Default Re: 60' and ET footbrake vs 2 step
Originally Posted by e vassar View Post
Are you guys using an adjustable brake pressure switch? Are you adjusting RT with brake pressure? Launch RPM? Or both?
I have an adjustable brake pressure switch. It has separate adjustments for ?arming? the 2 step and ?releasing?. This can effect reaction time a little, but mostly I use RPM adjustments for R.T.
1189 F/SA
Defunzalo Racing Enterprises
Doug Hoven is online now   Reply With Quote
Old 10-23-2024, 01:47 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
I’m new to 2steps (previously raced transbrake cars) not knowing where to start I’m at 2800 rpm using an electrical switch on the pedal. I see cars that roll forward before lifting the front tires and that would seem to be the best rather than picking them up out of the beam. I haven’t tried footbrake since the first two runs on the car. I’m also going to try and compare the difference. I have bias tires on the car now and 60’ 1.37-1.39 but plan on switching to radials. Is the leave comparable or am I going back to the beginning?
Mike 7570 A/SA
Mike Gray is online now   Reply With Quote
