Liked 369 Times in 127 Posts
.05 sec. for my 4 cyl. stocker
2 step vs. footbrake but then again it's a turbo car so maybe that data does not apply to a n/a setup
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
To borrow from former NBA great Dr. J. (Julius Erving), "I'M OLD-SCHOOL", so footbrake racing is the way I go.
Besides, that's one less part in my car that can go bad when it's supposed to be good!
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) Last edited by GarysZ24; 10-19-2024 at 05:58 PM. |
Liked 271 Times in 107 Posts
Are you guys using an adjustable brake pressure switch? Are you adjusting RT with brake pressure? Launch RPM? Or both?
Liked 863 Times in 165 Posts
I have an adjustable brake pressure switch. It has separate adjustments for ?arming? the 2 step and ?releasing?. This can effect reaction time a little, but mostly I use RPM adjustments for R.T.
1189 F/SA Defunzalo Racing Enterprises |
Liked 689 Times in 198 Posts
I’m new to 2steps (previously raced transbrake cars) not knowing where to start I’m at 2800 rpm using an electrical switch on the pedal. I see cars that roll forward before lifting the front tires and that would seem to be the best rather than picking them up out of the beam. I haven’t tried footbrake since the first two runs on the car. I’m also going to try and compare the difference. I have bias tires on the car now and 60’ 1.37-1.39 but plan on switching to radials. Is the leave comparable or am I going back to the beginning?
Mike 7570 A/SA Last edited by Mike Gray; 10-23-2024 at 02:33 PM. |
