View Poll Results: Agree or Disagree?
Agree 123 96.85%
Disagree 4 3.15%
Voters: 127. You may not vote on this poll
Old 10-18-2024, 10:53 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Default National Records Poll
Anyone who passes full teardown at Indy, or anywhere, should be awarded the record if they've broken the sitting record. Agree or Disagree?
Addition: This is assuming the 1% backup run requirement was satisfied as well as fuel and weight checked on said runs.
'65 Mustang SS/L & L/SA
Old 10-18-2024, 10:55 AM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: National Records Poll
agree
Old 10-18-2024, 11:39 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
I agree with that.
Mike Pearson 2485 SS
Old 10-18-2024, 12:19 PM   #4
J.R. Haddad
Liked 1,470 Times in 308 Posts
Good Poll Bobby. All we're talking about is bringing things up to date. We weren't allowed to set records at National Events in the past because the tech people were busy with teardowns from qualifying, then winners and runner-ups, pumping Comp cars and others, and teardowns from protests.
hence, we were regulated to the points meets and National Opens where the tech group would have time to accommodate the record setters. Fast forward to todays reality, where there are little to no teardowns, and it makes perfect sense that if your motor is coming down and you've exceeded the existing record, it is only 2 minutes of paperwork for NHRA to establish the runs as a new National Record. No need for NHRA to have any lengthy meetings, no weighing of pros and cons, there are no cons,
JUST DO IT!!
J.R.
J.R. Haddad is offline   Reply With Quote
Old 10-18-2024, 01:15 PM   #5
Frank Castros
Liked 2,738 Times in 965 Posts
I agree.
Old 10-18-2024, 01:59 PM   #6
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Nice! I agree.
Old 10-18-2024, 02:23 PM   #7
Hacksaw
Liked 311 Times in 175 Posts
The only problem I see is that they don't always check fuel or weight after every run. Unlike when you claim you are trying a record run.
Old 10-18-2024, 07:19 PM   #8
tstickff
tstickff's Avatar
Liked 561 Times in 138 Posts
If they do tear down at Indy they have checked fuel and weight, that?s the first thing they check.
Tim Stickles
tstickff is offline   Reply With Quote
Old 10-18-2024, 07:48 PM   #9
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Absolutely !!!!!!!
Bob Bender 144 O/SA
Old 10-18-2024, 10:47 PM   #10
west coast
Liked 223 Times in 73 Posts
Here is an idea, anybody that runs faster then the current national record gets torn down and if passed gets the record. This would put the fear back into passing a teardown and curb the cheating. If the record was at a minimum people would be scared and change to a class that does have a actual record which would make more heads up runs and get combos in line
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
