Old 04-20-2024, 07:49 AM   #13
Liked 11,028 Times in 2,266 Posts
Default Re: Engine assembly bench or engine stand
That’s some good thoughts Billy.
It would be fun to build one on the bench and dyno the engine. Take off of dyno remove heads and pan, loosen caps on mains and rods install on stand and reassemble then dyno.
With the block I run you can breathe on it and it changes.
