Liked 71 Times in 38 Posts
Liked 327 Times in 121 Posts
If it pulled them out of shape which is very possible with a stock Ford block, it should still go back to where it was when taken off the stand. A cylinder will go out of shapre with the plate or head off but go back in shape when they are put back on.
“ should go back” might be the key phrase there.I’d think they would have some resiliency but how much? I don’t know if Glidden sleeved any of his blocks,but if he did that would change things also.
Liked 1,922 Times in 432 Posts
I've always used a stand. At least to finish. I have put the cam and crank in on a table, some times. But always finished on a stand.
Alan Roehrich 212A G/S |
Liked 2 Times in 2 Posts
This is the answer, holds both ends of the engine, so no rear cylinder bore issues: https://www.summitracing.com/parts/otc-1735b
Liked 7,882 Times in 1,753 Posts
Ya know, if this is really such an issue, then shouldn't the engine be assembled with a transmission case bolted to it and sitting in the car, on the mounts?
Liked 10,969 Times in 2,261 Posts
That’s some good thoughts Billy.
It would be fun to build one on the bench and dyno the engine. Take off of dyno remove heads and pan, loosen caps on mains and rods install on stand and reassemble then dyno. With the block I run you can breathe on it and it changes. |
