Liked 19 Times in 4 Posts
If I understand the Class Racer Info site correctly...
A 91-93 Ranger can run in SS GT/TA through D depending on engine combo. Is this is a possibility? Brad Last edited by bpete; 04-03-2024 at 04:44 PM. Reason: text |
Liked 54 Times in 12 Posts
You are correct. They did away with the 250lb + or - a few years back in GT
Liked 415 Times in 88 Posts
Not sure I have seen a ford ranger in the GT class, that would be cool, hope you can make it happen. John
I need to look into it a bit further.
I have a donor chassis. Some of the aluminum replacement heads look like they are not available for some combinations. Acceptable cross-member modifications are also of a concern. IE what can be trimmed and or replaced within the class guidelines.. Brad |
Liked 312 Times in 175 Posts
You need to maintain the upper and lower control arms, otherwise cut out and trim as much as you need for clearance. However you will need to add reinforcement, as a tube/plate under the oil pan.
