#31 |
Liked 239 Times in 94 Posts
As delivered that 375hp 396 Camaro ran high 13's. Some racers have found a few tricks to get a bit quicker ET's...
#32 | |
Liked 9 Times in 3 Posts
That combination is a natural N/SA at 3505 with driver. 13.00 index. With headers, trans, converter, gear, and better tune, you'd be in the ball park of a little under. Like one said, you can scoop these cars up cheap as flood cars or just worn out used. Possible dime rocket potential since there's plenty of aftermarket available for them you can get used, and it's nice these have the 8.8 already under them. Decent compression ratio allowed as well. 12.48:1
Andy Warren, FSS/E 3464, A/NMC 1 10 Time NMCA Nostalgia Muscle Car Champion 2020 NMCA Stock/Super Stock Combo Champion Last edited by 2Ton71; 11-27-2023 at 07:45 AM. |
#33 | |
Liked 217 Times in 93 Posts
BUT, Blue Oval fans! There is nothing in the classification guide to cover any Ford car after 2019!! You guys need to be contacting Ford to get your specs to NHRA. Even the years between 2015 and 2019 stink. You are all set if you want to race a Focus but NOTHING ELSE is there. I hope someone steps up to get these specs to NHRA. Merry Christmas, Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
#34 | |
Liked 755 Times in 213 Posts
#35 |
Very Nice! I'll check it out
Andy Warren, FSS/E 3464, A/NMC 1 10 Time NMCA Nostalgia Muscle Car Champion 2020 NMCA Stock/Super Stock Combo Champion |
#36 | |
Liked 72 Times in 20 Posts
#37 |
Liked 405 Times in 158 Posts
As far as the 3.7 ford engine, it's dohc/4v/alum head and block. From the factory, in a 2011 f-150, it shifts (from the factory) at 7000rpm. This is an awesome engine, can't believe it's the "base" to replace the 300 six!
Here is me racing it, put it in drive, let it shift itself. (spoiler, I won!) |
#38 | |
I spoke with Chevrolet about convertibles on several occasions and was told flat out that they did not want to add them. The same goes for the 2014-15 Z28 and later Corvettes.
Daren Poole-Adams NHRA Stock/SS 2007 |
#39 | |
