Old 09-26-2023, 11:19 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Beware of CSR Performance
Originally Posted by FLEMING View Post
What is the new rule?? I knew they were requiring sfi flexplate.. but didnt know about the shield.. all automatic cars?
not a new rule...
General Regulations Section 21, page 17
2:14 TRANSMISSION, AUTOMATIC/NHRAACCEPTED
All cars running 10.99 (*6.99) seconds and quicker must have
an NHRA-accepted locking-type dipstick on the transmission,
and dipstick/filler tubes must be securely fastened (i.e., bolted,
aircraft clamped). Wire ties, hose clamps, etc. prohibited.
Any non-OEM automatic floor-mounted automatic transmission
shifter must be equipped with a spring-loaded positive
reverse lockout device to prevent the shifter from accidentally
being put into reverse gear. Functional neutral safety switch
mandatory. All transmission lines must be metallic or highpressure-type hose.
All vehicles running quicker than 10.99
seconds (*6.99) or faster than 135 mph (except some Stock
and Super Stock classes as noted under Class Requirements)
and using an automatic transmission must be equipped
with a transmission shield meeting SFI Spec 4.1 and labeled
accordingly. (“Blanket”-type shield, appropriately labeled as
meeting SFI Spec 4.1, permitted.) All non-blanket-type shields
must incorporate two (or one, per manufacturer’s instructions)
3/4 x 1/8-inch straps that bolt to the shield on each side and
pass under the transmission pan, or transmission pan must
be labeled as meeting SFI Spec 4.1. Permitted in all classes
where an automatic transmission is used.
Comp, Super Comp, Super Gas, 9.99 or quicker E.T. cars, and
135-mph or faster E.T. cars using an automatic transmission,
Lenco Drive, or BRT must be equipped with a flexplate meeting
SFI Spec 29.1 and covered by a flexplate shield meeting SFI
Spec 30.1.
Transmission that can utilize a high-gear transbrake
must be supported by the use of two momentary buttons
(one to arm the system, second as the main transbrake). Air
shifter bottles must be stamped with DOT-1800 pound rating
(minimum) and be securely mounted (i.e., no tie wraps or hose
clamps).
Old 09-26-2023, 12:47 PM   #2
Billy Nees
Liked 7,769 Times in 1,741 Posts
Stock/Super Stock - Beginning January 1, 2024, SFI Flexplate mandatory on all V8 vehicles.
Billy Nees 1188 STK, SS
Old 09-26-2023, 01:01 PM   #3
1320racer
1320racer's Avatar
long overdue. too many old guys still running 50 year old flexplates and others chinese junk.
Old 09-26-2023, 01:40 PM   #4
Billy Nees
The 50 year old flexplates aren't the problem and neither is the good stuff (ATI, Meziere). It's the Chinese stuff.
Old 09-26-2023, 02:29 PM   #5
DG
DG's Avatar
Liked 449 Times in 98 Posts
My mistake, I confused the new SFI flex plate rule with the old 9.99 flex plate shield rule. Since I am moving to A/SA, their both new rules for me to comply with.
DG is offline   Reply With Quote
Old 12-14-2023, 10:47 PM   #6
goinbroke2
Liked 393 Times in 153 Posts
I see 10.99 or quicker, where does it say all?
Edit: Just found it...I guess I have to spend more money...to run in the 14's, LOL!!! Good news is they are cheaper than I thought.
Old 09-26-2023, 03:57 PM   #7
FLEMING
Liked 54 Times in 25 Posts
Ok, i knew about this.. I just thought it had gotten changed for the slower class cars as well..Doesnt effect me lol
Originally Posted by 1320racer View Post
not a new rule...
Spec 30.1.
clamps).
FLEMING is offline   Reply With Quote
Old 09-27-2023, 10:11 PM   #8
Tuffbox56
Liked 3 Times in 2 Posts
Ken Keir Race Cars sells a really nice lightweight trans blanket/shield. Keeps heat down works on metric and th350s.Give ken a call he is super reaponsive and sells great products...
301 704 7046
Tuffbox56 is offline   Reply With Quote
Old 12-13-2023, 04:25 PM   #9
DG
DG's Avatar
Thought I would give an update on my Trans shield order from CSR. In September CSR called me to say the trans shield was going to production and shipping by the end of the week. They charged my credit card. Of course the shield has not arrived and this morning they claimed it would go out the first week of January. If I had other options for my race car, I would cancel the order, but I do not have options. If I don't get it in January, I will definitely work through my credit card to get my money back.
Old 12-13-2023, 05:01 PM   #10
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Terrible. Sorry that you didn’t hear about them before you ordered. They’ve been awful for along time….
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
