#71 | |
Liked 327 Times in 121 Posts
#72 | |
This just occurred to me .This, being a Chevy II with fenderwell headers, the car didn't have much in the way under it to absorb and block some of the explosion. With Jimmy Jr. on the right in the waterbox, it sounds like he was caught in a perfect storm, so to speak..Lucky, lucky ,lucky!
#73 |
Liked 66 Times in 31 Posts
It pretty much destroyed the bell housing. Most of the parts were about the size of your hand. It was a stock bell.
#74 |
Liked 72 Times in 27 Posts
Here's a 301 Pontiac stocker crank internally balanced!
#75 | |
Guest
Posts: n/a
#76 |
But the bottom line still is the fact that a 10.0 bracket car doesn't need an SFI flex plate and there are probably a dozen or more 10.0 to 11.99 of them for every N/S and lower Stocker out there. The SFI deal should be 11.99 and quicker.
Pat, Lonnie, are you listening? Or would you rather that I give you both a call?
#77 | |
I would like to think that this ruling will be aligned with the need for trans and flexplate shields based on E.T.s and not just an arbitrary ruling based off of a "million-to-one" incident. And I've got a "Billy question" here, since this "issue" involved the starter ring gear and not the actual flexplate itself, are Mopars going to have to have SFI approved torque converters?
#78 |
From what I got out f this conversation, you can't.
#79 | |
#80 | |
Does NHRA know that a Div. 1 Racer who will go un-named lost a ring gear off of an SFI approved flexplate in Columbus last weekend? Why is that? I personally believe that I would rather put my faith (and lower extremities) in a 50 year old GM piece over something imported from China! Especially in a 12.0 or slower car! And NHRA, if you're going to continue pursuing this, when are you going to start with the SFI approved torque converters for the Mopars? If the ring gears really are the issue then it only seems right!
