Old 05-24-2023, 05:24 PM   #1
L.Fite
Liked 497 Times in 243 Posts
Default Re: Cooters Goat
Curious of the actual cause of the mayhem...
Sounded like a flywheel issue.
Haven't seen anything like that since the Porter days, and that was a balancer that came apart pre SFI.
L.Fite is offline   Reply With Quote
Old 05-24-2023, 06:24 PM   #2
Greenlight
Liked 79 Times in 22 Posts
Here are some photos. This could have been REALLY bad. I have an unconfirmed rumor that the back of the crankshaft broke off. I'm not sure if this is true or not.
Greenlight is offline   Reply With Quote
Old 05-24-2023, 06:41 PM   #3
Danny Rucker
Liked 2 Times in 1 Post
I was in the barn when they pulled the trans.
Crankshaft was not broken. What remained of the flexplate was still bolted with all bolts to the crank. Approximately 2/3 of the flexplate was still there.
Parts of flexplate and ring gear were gone. The Trans case bell and ears were broken off.
Danny Rucker is offline   Reply With Quote
Old 05-24-2023, 08:59 PM   #4
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
What happened?
Lane Weber
Old 05-24-2023, 10:04 PM   #5
FED 387
Liked 333 Times in 180 Posts
OUCH!!!!!! has he got all his toes??? FED 387
Old 05-24-2023, 10:27 PM   #6
A/SA Fairlane
Liked 57 Times in 19 Posts
Originally Posted by The Hawk View Post
What happened?
The car in the other lane exploded the flex plate on the burn out.
A/SA Fairlane is offline   Reply With Quote
Old 05-24-2023, 11:34 PM   #7
Mike Schwartz
Liked 248 Times in 89 Posts
This all happened during round 1 of Stock on Sunday. Jimmy was going to be racing Bill Basham. The video is here (you'll have to scroll back to the 1:00:10 point):
At first it's only the announcer talking over the results screen from the previous match. After about 2½ minutes they switch back to the camera and you can see the aftermath.
Last edited by Mike Schwartz; 05-24-2023 at 11:40 PM. Reason: Video placement & time stamp
Old 05-25-2023, 10:18 AM   #8
devo340
devo340's Avatar
Liked 168 Times in 30 Posts
I'm standing over the wall from the water box.
Bashum started his burnout & the flywheel ring gear came apart.
I have a inch & half piece that I picked up.
Went through the 1/4 panel & busted out the right side 1/4 window.
Could have been worse.
devo340 is offline   Reply With Quote
Old 05-25-2023, 11:46 PM   #9
Greenlight
I'm curious if all the transmission bellhousing bolts were tight?????
If bolts were loose, and transmission/converter were slightly cocked, the flexplate would be the first thing to go as it continuously bent back and forth with each rotation.
If so, the broken surface of the flexplate would leave clues if the failure was a cyclical bending failure.
Old 05-26-2023, 06:15 AM   #10
HR9121
HR9121's Avatar
Agreed. The ears of the bellhousing being broken off indicate to me there was something else going on there other than the flex plate coming apart.
James Williamson
W200 J/SA. SS/JA
