Liked 161 Times in 52 Posts
28s are the biggest they can run
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Liked 58 Times in 36 Posts
I used to run the 28x10.5 Stiff in Renegade. Back then we had to weigh 3000 and made more HP 850 but with a single disk Ram and a adjustable pressure plate I 60 footed 1.25 and ran 9.0’s a DOHC 4.6
I know this isn’t your combo but it’s about as close as you’re going to get here!
SS/AH 328X |
Thank you, James. This is very helpful and something I will consider. As you know, I will need to balance clutch slip, wheel speed, and rotating weight, so I will probably need to test with a short tire/gear package, vs a tall one. Thanks again.
Liked 805 Times in 245 Posts
Stick to basic 'meat and potatoes' components that have been working for Stock class cars for years, Soft Lock, alum flywheel, G101 and the 10 x 28 should be plenty of tire to get you well into the 9 second range. Run the clutch as loose as you can get ways with and oh yeah, don't use the clutch to shift.
#5 | |
Liked 20 Times in 16 Posts
Grant
Grant website- http://ClutchTamer.com We make your non-adjustable clutch...ADJUSTABLE! |
Correct, and a “Diaphragm Pressure Plate assembly is required”.
