Liked 2 Times in 2 Posts
Greg, I don't know your reason for wanting to switch your disc. to drums, but if it is to get rid of some weight be careful. Many years ago I had a 69 Chevy 2 with factory disc. on the front & was told I could get rid of 40 lbs. going to the drums. Had a friend with a Camaro with front drums, we made a trade I even did all of the work, well the only thing that I lost was time & alot of braking power. I weighed the parts as I was making the switch, the weight difference was nothing, but a deal is a deal & he was a happy camper. My car ran low 10's 130 mph. & it was hard to stop after that switch. Danny
Liked 5,121 Times in 1,952 Posts
Should be a bit lighter, from my experience..
Also ,less drag Plus, it's easier to heat and bend the drum brake steering arms for toe-in issues. Greg, Just do it..Nobody cares (except for maybe a few keyboard racers)
Liked 705 Times in 219 Posts
One thing about this whole deal, the discs were all power assist with the big round booster on the fitrwall. Drums either came power or manual. Running a vacuum booster with any kind of performance camshaft would absolutely not work,especially a Stock Eliminator type cam. That would be a weight saver as well.
Liked 1,104 Times in 302 Posts
Prior to NHRA allowing lightweight, aftermarket disc brakes, many racers s swapped out the factory disc brakes for manual drums. As Mark said, less weight, and could be adjusted for zero drag. Funny, how, when many of the fast, higher classed cars, that had replaced the factory discs, for drums (and often to very light, small, 6 cylinder drum brakes), started lobbying for "Better" (read that as even lighter) aftermarket brakes, it became all about safety. Kinda like when lightweight racing seats were requested , again for "Safety". Have to wonder how many racers would have installed the aftermarket seats if they had to be the same weight as the seats being replaced, or heavier. I would guess "safety" would not have be as much of a concern in that case! As for the drum brakes, my buddys SS/F 66 Chevelle ran 9.7s at 138 MPH, on the stock 9 1/2" drum brakes, and another buddys 67 Mustang bracket car ran the same numbers with the original 10" drums. Neither had stopping issues, despite both being stick cars that went into neutral at the finish line, so no engine braking. Of course that also depends on the shut down length of the tracks being raced on. Cold drum brakes also often hold the car in the burnout box better than some manual disc brakes as well.
Liked 27 Times in 14 Posts
My dads 68 chevelle c/s 3680 pound car had drum brakes on it .at phoenix he could barely get it stopped at the turn off we had to put new shoes on it every race because they would get cracks in the pads on the shoe.go with disc brakes stock or after market. much safer .unstead of push and pray you stop.
Liked 91 Times in 29 Posts
My ex-modified eliminator camaro has drum brakes up front. With times of high 9's to low 10's and speeds of 130s it was a bear to stop.
Bruce Cameron 68 Nova 396 E/S 68 Camaro SS/? ex Checkmate Modified |
Liked 54 Times in 27 Posts
If you go from power to manual brakes, remember to include a retainer so the pushrod cannot fall out of the master cylinder cup.
