Old 11-10-2022, 10:25 AM   #21
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Default Re: Radial tires
It's been quite a few years since I tried Goodyear radials.
From what I remember, they may have been a little faster,but I had more inconsistency.
Everyone has their own opinions,but in my opinion, the Hoosiers are tough to beat.
Old 11-10-2022, 11:03 AM   #22
Liked 10,783 Times in 2,242 Posts
When we were at a tire test we did two back to back tire tests, within a time window and the Goodyear’s on my Cuda were quicker and faster than the Hoosier Radial.
For me besides the great longevity is the ease of the rubber removal from the rear fenders.
Old 11-10-2022, 01:27 PM   #23
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
You need Daryl to hook you up with some of those mud flaps.
S/ST 51
S/C 53
Old 11-10-2022, 07:50 PM   #24
GTX JOHN
I tried a significantly shorter burnout this morning at World Finals,
But the car exploded the tires immediately. Second pass went back
to regular burn out and no problem. 18 PSI's both passes.
John Irving
741 Stock
741 Super Stock
Old 11-11-2022, 07:43 AM   #25
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Originally Posted by Troy Henderson View Post
They can definitely work if you take the time to set the car up for the tire.
Can you elaborate?
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 11-11-2022, 07:58 AM   #26
No mud flaps for me it’s to much aero drag. I loose it or gain it .001 of second at a time.
Old 11-11-2022, 10:38 AM   #27
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Originally Posted by 427FE View Post
Can you elaborate?
Radials need to be dead hooked with even then increasing pressure right off the hit to work consistently. Basically just like an automatic car leaves. If your car pounds the bias tires hard to make it leave it may not be able to hook radials. Good shocks, sorted suspension and data logging go a long ways.
https://photos.app.goo.gl/mNJHBABXRNpW43cYA
Troy Henderson is online now   Reply With Quote
Old 11-11-2022, 03:34 PM   #28
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
When did you switch to a Metric 200
Bad to the bone !!!
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is online now   Reply With Quote
Old 11-11-2022, 03:54 PM   #29
Troy Henderson
Cool Re: Radial tires
Bad to the bone !!!
You know I'm allergic to red fluid
Old 11-11-2022, 04:35 PM   #30
James Perrone
Liked 1,829 Times in 427 Posts
Are you running a radials in the video?
Car leaves perfect
james perrone 1290 STK
