Liked 7,886 Times in 1,753 Posts
It won't come to that if they can come up with something somewhat easy to police. Maybe stock dia. and height +/- something and no more than 180/200 on the seat.
#2 | |
One of the best posts in a very long time. Bravo Bubski!
Liked 2,343 Times in 465 Posts
Bubski Grow a pair and use your real name.
Frank I'm sure we must have met threw the years but do you even have a Stocker? Paul you and Charlie are trying to get a motor built. What are you going to use for lifters? Or are you going to put a small cam with not a lot of valve spring pressure. There are others on here with a solution to go backwards for the older cars. Some of you don't race Stock and probably never will. Others race in classes that they don't have anyone that competes in their class and won't see a heads up race all year. I'd call that bracket racing and you don't need to worry how fast your car goes. I like the part of competing against other cars that run the same class as I do. And I don't want to have to bring a knife to a gun fight because a part is no longer available. James so you have an experiment going on. I hope they work all season. But if not let us know how big of a hole in the oil pan they put and what it will cost to fix. I don't need any lifters at this point. But with everything we are allowed to do right now. And with half the cars in Stock using roller lifters already. You think letting all Stockers use them is going to make us closer to Super Stock. Really!! That horse left the barn years ago too. Bubski pay attention to this. I USE MY REAL NAME again if your going post on here why don't you first grow a SET !! Until then I look at your post's as a no name CLOWN. Barry Parker Last edited by B Parker; 11-04-2022 at 07:55 PM. |
#5 | |
Liked 187 Times in 58 Posts
John Ancona 717 STK / SS |
Liked 10,969 Times in 2,261 Posts
Y’all get the rules fix and we will try to live by them.
#7 | |
Liked 232 Times in 108 Posts
Liked 1,032 Times in 283 Posts
I think the biggest problem would be fuel check.
Duane Hoven 1342 SS/GT |
Liked 508 Times in 92 Posts
I still remember the spring numbers, 98 lbs seat and 202 lbs open. I was tossed once for being 2 lbs over. I'd be fine going back but that's just me being a purists for Stock. True hydraulics and only oem solid lifter cars. That would make nobody going 1 second under.
I not saying that it should go to the old way, just an opinion. Casey Miles 248H Stock |
Liked 557 Times in 217 Posts
Hydraulic Chevy cams were allowed the stock spring at about 84-86lbs on the seat. Single spring with a flat damper.
6000 rpm give or take a few hundred was all you were good for...1970 Stocker....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 11-05-2022 at 07:43 PM. |
