Old 10-18-2022, 06:59 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: Hey Troy Huntzberry, Do The Right Thing!
No pup in this fight, just need info. What about going up staging, break the beam and getting pushed back for the win, is this still legal? Do you still have to go down weigh and fuel check. Did his opponents time slip say looser? Did his opponent go over the scale before going to his pit, this used to be a automatic DQ. Lots of questions few answers. Maybe Bobby needs to have the Div Director on Tech Tuesday pod cast .As long as the dial in is the index or below should be legal. If the other guy would have looked up at the score board and seen that his win light was not on he should have lifted, that's twice on 1 run. Most of usually get only one chance at screwing up and still winning. Its going to be a long winter.. Tom
Tom Meyer 5240 SS Stock ???
Old 10-18-2022, 07:11 PM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Originally Posted by Tom Meyer View Post
No pup in this fight, just need info. What about going up staging break the beam and getting pushed back for the win, is this still legal? Do you still have to go down weigh and fuel check. Did his opponents time slip say looser? Did his opponent go over the scale before going to his pit, this used to be a automatic DQ. Lots of questions few answers. Maybe Bobby needs to have the Div Director on Tech Tuesday pod cast. Its going to be a long winter.. Tom
Yes, you must stage and take the green, which Casey did. He also went down the track and scaled. The time slip (both drivers got the same one) gave Casey the win. The video shows the win light in Casey's lane after Troy broke out. This was not a bye run just because Casey broke on the run. Troy was making a run in competition. I have no knowledge if Troy scaled after the run or not. I have to assume he did. It used to be in the old days you had to make the run under your own power, great for the spectators, watching the driver push his car down the track, but that took too much time and that was abolished and the broken car can be towed. Jim
