#11 | |
Liked 282 Times in 103 Posts
#12 | |
Liked 508 Times in 92 Posts
Casey Miles 248H E/S |
#13 |
Liked 2,746 Times in 969 Posts
What in God's name is going on at these races.
D7 and D2 shame! D6 is like a secret society. I don't recall seeing this crap in D1, D3 and D4 or am I wrong? |
#14 |
#15 |
Liked 561 Times in 138 Posts
I’m confused, what should Troy do at this point? If The Who’s who of D2 made the decision as it is now, what should be rectified? Just for future reference…thank you!
Tim Stickles
Tim Stickles |
#16 |
Liked 10,837 Times in 2,252 Posts
Simple, the person making the decision should know and understand the rules in the rule book then apply them.
The DD has the power to change the outcome of a race but should they use it. It's spelled out in the race procedures. It wasn't a first or worst ruling. |
#17 |
Liked 1,947 Times in 588 Posts
I have been burned by a wrong dial in before. After that happened I check my dial in every round before I pull in to the pre stage beam. I have had to get it corrected several times. Once you stage and the race is on you own the dial on the board. Mistakes do happen and you have to do what you need to do by making sure your dial is correct.
Mike Pearson 2485 SS |
#18 |
Liked 11 Times in 6 Posts
Just to clarify something for everyone and clear up any misconceptions.....per the NHRA rulebook (Section 2, Page 2 under Staging in the 2022 book) a racer has accepted the dial-in when they PRE-STAGE not stage. This has apparently been the rule for years and it bit me at the Charlotte national event a few years ago when I backed out of the pre-staged beam and told them the dial-in was wrong and they wouldn't change it and they fired the tree and red lighted me.
#19 |
Thanks Jack that is how I read the rules.
#20 |
Liked 239 Times in 90 Posts
The fact that Casey was pushed off the track with track equipment would be a "disqualification" of the run per the Rule Book. Bye runs are the only allowed run where you do not have to cross the finish line under power. You can not get a "time" when being pushed
