#51 | |
Liked 706 Times in 283 Posts
Pushrod deflection, particular valve sping pressure ect. |
#52 | |
Liked 1,603 Times in 583 Posts
Valvetrain behavior is affected mainly by the dynamics of the camshaft lobe and rocker arm and pushrod deflection. As a result, Spintron testing has helped with the reduction of spring pressures, the use of stiffer pushrods and many have switched from aluminum rockers arms to CNC machined/profiled steel rocker arms with Jesel shaft rockers. Like my friend Robin Wright says, the key is to control a "pissed off" valvetrain. |
#53 | |
Liked 7,800 Times in 1,747 Posts
OBTW, ANOTHER reason to appreciate those "old" Tech guys!
#54 |
Liked 10,793 Times in 2,244 Posts
I for one have had, lifter problems both ceramic and steel, cast core cam failure, and an oil pan full of steel shavings from a ceramic lifter failure on a steel cam. Each time a failure occurred we lost everything but the heads, intake, rods, and sheet metal. I put eight sleeves in a block, the block broke after a few runs. So we , a bunch of smart people that have helped me, have attained a small amount of reliability with the six pack car.
The cam is factory size journals and lift I know the other shoe will drop sooner but I hope it later. |
#55 | |
Liked 2,354 Times in 554 Posts
The demand for roller lifters seems to be presented as a way to cut costs. Could the same argument be made to take a step back to simpler times? I'm not picking. I respect you and know that you work hard.
Daren Poole-Adams NHRA Stock/SS 2007 |
#56 |
Liked 92 Times in 26 Posts
I would like to see valve spring pressures for "stock" to be set at 200#'s , unless OE was more , then set at factory specs. Should remove the need for all the enhancements requested for more exotic valve train.
In my opinion , opening up the spring rule (or lack of a rule) started all this rule changing requests. If you want a jessel , roller cam , lighter this or that , then Super Stock or comp , or? Is the Class is for You NOT STOCK!!! |
#57 | |
The biggest contributor of failures is dissimilar materials, finishes, treatments, changes on the engine oil additives/composition and break-in process. The camshaft lobes and lifter surfaces are high load contact areas, and although they may be considered highly polished contact areas, immersed or sprayed with oil, there is still some surface asperity or roughness and the reason why many engine blocks have enclosed camshaft tunnels and many enclose the camshaft tunnel area. Flat tappet camshafts and flat tappet hydraulic and solid lifters, also need to have a specific taper on the lobe and lifter crown. I have seen too many aftermarket camshafts and lifters that have been ground without enough taper, preventing the lifter to rotate, especially with high pressure valve springs. Many of the ceramic flat tappet lifters that I have seen,do not have any taper on the crown, therefore, you have a very high contact area that eventually will wear, causing a catastrophic failure. When you have the proper taper, the engine will require a camshaft thrust plate or stop to control its movement. Nevertheless, when you have a thrust plate or stop, you also need to have the appropriate clearance because being too tight, will also prevent the rotation of the lifter. Material compatibility between the camshaft and lifters is also a big source of failures and also the lack of Zinc and other oil additives are also a culprit. My preference of break in oils is Maxima or Joe Gibbs. For roller cams, I recommend the use of a Calcium Sulfonate based grease or lubricant such as Lubriplate 130-AA Multi-Purpose Calcium Type Grease. Calcium Sulfonate based grease is designed for high contact areas and I apply it to the roller camshaft lobes only. |
#58 | |
Liked 183 Times in 48 Posts
It bears mentioning that there can also be issues with pushrod angularity. Steep angles between the lifter and pushrod will cause bias pressure on the lifter. I have offset lifters on my modified engine to try to compensate for the difference in width between the lifters and the rocker arms. They are top-shelf lifters but even with 50 passes on them, you can see the wear pattern from the pressure bias. The fix is to machine the block so the lifter bores align with the rockers, side to side. That way the pushrods will be straight without using offset lifters. With the splayed head, the bore angles also need to be changed front to back to remove the angularity caused by the valve/rocker placement. The lifter bores for my application need to look like a standard BBC.
SS/BS 1921 |
#59 |
Liked 867 Times in 165 Posts
I'm not sure which changes you would be referring to, but both of the combinations that Todd has built throughout the past 20+ years have not been given a great deal of the "enhancements" that combinations in the same classes have been given. Ok, maybe the 12 bolt rear in place of a 10 bolt is one, but I can't imagine that rule change having a similar reaction than allowing anyone to run a roller lifter in there engine.
1189 F/SA Defunzalo Racing Enterprises Last edited by Doug Hoven; 01-06-2022 at 03:11 PM. |
#60 |
Ceramic lifters failure seems to start the snowball rolling for engine destruction. We brake the cam in on a fixture, run it on a dyno, race it with break in oil and then the ceramic lets go and it’s back to square one.
