Old 01-05-2022, 08:12 PM   #1
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Explain to me again, please
When the Cam Duration and Valve Spring rules were changed many years ago that created a Domino effect that changed Stock Eliminator forever.
Just my opinion, but I think you are hitting on the reason for changes such as these. Simplification of tech because they have lost most everyone that could accurately measure cam duration. Almost every change looking back over the last few years has been to make it easier on the tech officials if they ever do look at something. Same thing with the lifter issue. Anyone can eyeball a roller vs flat and it is easier to measure lift without replacing the lifter with a solid if it is already solid.
Could be all wet, but this is why I think we see changes like these. This is not to be read as I agree with the simplification for them to do their job.
KRatcliff is offline   Reply With Quote
Old 01-05-2022, 08:57 PM   #2
Frank Castros
Liked 2,727 Times in 961 Posts
You're correct about their ability to properly check Cam Duration and shame on the N.H.R.A. for that. Greg Xakellis had a great team then and it was not a D1 issue and I doubt it was a D3 or D4 issue either as they also had great teams as well. But the Valve Springs? Come on man, anybody can check spring pressure.
Old 01-05-2022, 09:09 PM   #3
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Explain to me again, please
Put the "stock" back in "stock".... good start would be Pressure on valve springs.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 01-05-2022, 09:32 PM   #4
L.Fite
Liked 497 Times in 243 Posts
The point, however, is that if a 750-850 HP, 358 CID, canted valve, flat tappet engine in a Cup car can run 500 miles at over 9000 rpm with a stock diameter solid lifter, then it's hard to imagine why it can't be done in a stocker that doesn't anywhere near that RPM and is raced a quarter-mile at a time.
You're still comparing apples to grapes...
The technology used to make a NASCAR engine live is so for advanced it makes a SS engine look like a high school mechanics class project.
L.Fite is offline   Reply With Quote
Old 01-05-2022, 10:13 PM   #5
SBillinson
Liked 183 Times in 48 Posts
You're batting a thousand on being wrong. Apparently, you haven't seen the inside of a well-developed Super Stock engine. By the way, I have several Cup engines, so please stop embarrassing yourself.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 01-05-2022, 10:45 PM   #6
L.Fite
Don't know who you are... don't care...
I know what I've seen...
I'm not interested in getting in a pissing match on the inter web...
I have more important things to worry with...
Have a nice day...
Old 01-05-2022, 10:51 PM   #7
SSDiv6
Liked 1,583 Times in 582 Posts
I worked for a period of time for the former engine shop director for Robert Yates, Penske Racing and later on, Richard Petty. He spent lots of time sharing tidbits of the technology used in NASCAR on racing engine building. The only aspects that I see are advanced in NASCAR is the machining processes, equipment and materials used in the parts for longevity. Of course, they also spend millions on R&D and testing, and yes, we run more radical camshafts. Nevertheless, some of the qualifying engine cams have radical profiles and spent lots of hours and days doing Spintron testing, learning to control the valvetrain that is one of the main keys for making power.
As regards to camshafts, the cores are billet and treated. The camshafts are not broken in th engine. Every camshaft is broken-in by installing the cam in a specific machine the simulates the lifter contact and load, and different RPM levels and temperatures, being sprayed with engine oil during the operation. After the camshaft was broken in, then it would go into the assigned engine. The choice of hardened steel solid lifters made by either Trend, PPPC, Isky and Crower.
The other key for making power in NASCAR is sealing the engine, spending lots of time testing hone finishes and piston ring materials and configurations. All the torque plates we had in the shop, were custom made. The thickness of the torque plates mirrored the height of the actual cylinder head, with all the fasteners and hardware having the same length and diameter as the ones used in the engine. They were not the normal thickness of torque plates used by most shops, and many of the torque plates had provisions for hot honing.
There is more to building a fast engine than putting a big cam and stiffer valve springs.
Old 01-05-2022, 11:07 PM   #8
Jeff Stout
Liked 704 Times in 281 Posts
Just talking about valve train today at shop. What was done to control valve train when using a Spintron?
Pushrod deflection, particular valve sping pressure ect.
Old 01-05-2022, 11:20 PM   #9
SSDiv6
Jeff,
Valvetrain behavior is affected mainly by the dynamics of the camshaft lobe and rocker arm and pushrod deflection. As a result, Spintron testing has helped with the reduction of spring pressures, the use of stiffer pushrods and many have switched from aluminum rockers arms to CNC machined/profiled steel rocker arms with Jesel shaft rockers. Like my friend Robin Wright says, the key is to control a "pissed off" valvetrain.
Old 01-05-2022, 09:37 PM   #10
L.Fite
You are probably correct... But it's going to be awful hard to stuff that genie back in the bottle...
