Old 01-05-2022, 09:32 PM   #1
L.Fite
Liked 497 Times in 243 Posts
Default Re: Explain to me again, please
The point, however, is that if a 750-850 HP, 358 CID, canted valve, flat tappet engine in a Cup car can run 500 miles at over 9000 rpm with a stock diameter solid lifter, then it's hard to imagine why it can't be done in a stocker that doesn't anywhere near that RPM and is raced a quarter-mile at a time.
You're still comparing apples to grapes...
The technology used to make a NASCAR engine live is so for advanced it makes a SS engine look like a high school mechanics class project.
L.Fite is online now   Reply With Quote
Old 01-05-2022, 10:13 PM   #2
SBillinson
Liked 183 Times in 48 Posts
You're batting a thousand on being wrong. Apparently, you haven't seen the inside of a well-developed Super Stock engine. By the way, I have several Cup engines, so please stop embarrassing yourself.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 01-05-2022, 10:45 PM   #3
L.Fite
Don't know who you are... don't care...
I know what I've seen...
I'm not interested in getting in a pissing match on the inter web...
I have more important things to worry with...
Have a nice day...
Old 01-05-2022, 10:51 PM   #4
SSDiv6
I worked for a period of time for the former engine shop director for Robert Yates, Penske Racing and later on, Richard Petty. He spent lots of time sharing tidbits of the technology used in NASCAR on racing engine building. The only aspects that I see are advanced in NASCAR is the machining processes, equipment and materials used in the parts for longevity. Of course, they also spend millions on R&D and testing, and yes, we run more radical camshafts. Nevertheless, some of the qualifying engine cams have radical profiles and spent lots of hours and days doing Spintron testing, learning to control the valvetrain that is one of the main keys for making power.
As regards to camshafts, the cores are billet and treated. The camshafts are not broken in th engine. Every camshaft is broken-in by installing the cam in a specific machine the simulates the lifter contact and load, and different RPM levels and temperatures, being sprayed with engine oil during the operation. After the camshaft was broken in, then it would go into the assigned engine. The choice of hardened steel solid lifters made by either Trend, PPPC, Isky and Crower.
The other key for making power in NASCAR is sealing the engine, spending lots of time testing hone finishes and piston ring materials and configurations. All the torque plates we had in the shop, were custom made. The thickness of the torque plates mirrored the height of the actual cylinder head, with all the fasteners and hardware having the same length and diameter as the ones used in the engine. They were not the normal thickness of torque plates used by most shops, and many of the torque plates had provisions for hot honing.
There is more to building a fast engine than putting a big cam and stiffer valve springs.
Old 01-05-2022, 11:07 PM   #5
Jeff Stout
Liked 704 Times in 281 Posts
Just talking about valve train today at shop. What was done to control valve train when using a Spintron?
Pushrod deflection, particular valve sping pressure ect.
Old 01-05-2022, 11:20 PM   #6
SSDiv6
Jeff,
Valvetrain behavior is affected mainly by the dynamics of the camshaft lobe and rocker arm and pushrod deflection. As a result, Spintron testing has helped with the reduction of spring pressures, the use of stiffer pushrods and many have switched from aluminum rockers arms to CNC machined/profiled steel rocker arms with Jesel shaft rockers. Like my friend Robin Wright says, the key is to control a "pissed off" valvetrain.
