Old 12-31-2021, 02:03 PM   #20
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Throttle Limiters
You're allowed 2 OEM type gaskets, IF you can find a gasket with a smaller hole in it then go for it! But it's gotta be a GASKET.
The EFI guys are making steel and aluminum plates and putting them between the throttle body and the manifold.
Why would you need 2 gaskets other than to put one on each side of the restrictor plate?
S/ST 51
S/C 53
