Old 12-31-2021, 01:40 PM   #1
4543
Liked 646 Times in 140 Posts
Default Re: Throttle Limiters
THAT isn't what I said!
I’m just trying to understand. Isn’t the effect of what you said the same?
4543 is offline   Reply With Quote
Old 12-31-2021, 01:51 PM   #2
Billy Nees
Liked 7,773 Times in 1,742 Posts
You're allowed 2 OEM type gaskets, IF you can find a gasket with a smaller hole in it then go for it! But it's gotta be a GASKET.
The EFI guys are making steel and aluminum plates and putting them between the throttle body and the manifold.
Billy Nees 1188 STK, SS
Old 12-31-2021, 02:03 PM   #3
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Why would you need 2 gaskets other than to put one on each side of the restrictor plate?
S/ST 51
S/C 53
Old 12-31-2021, 02:07 PM   #4
Billy Nees
Some carbureted combos like a larger "plenum" under the carb. Some don't.
