Old 11-03-2021, 12:25 PM   #20
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default Re: Project - NHRA Stock and S/S results 61-68
Originally Posted by DeuceCoupe View Post
I thought of a RA4 factored up past its 380hp factoring circa 1970 but that doesnt work because other cars show the RA4 was factored at 380hp since it hit the strip in early 1969.
So the only possible Pontiac that fits is a 68 Bird RA2, factored to 390hp.
I have no basis for that factor other than it makes the car fit.
3300/390=8.46
Any factor less than 390hp will knock the car down into C/SA=8.50 class.
Why would the RA2 be factored to 390hp when the RA4 was only factored at 380hp? Hard to explain.
IF all the info you have from back during that time period is correct, then:
(1) What year could the '68 Bird I posted a pic of have run B/SA ?
(2) What year could the '69 "Hatari" Bird have run B/SA ?
Both obviously DID run B/SA, at least 1 year, at least at 1 track, under some sanctioning body.
When ?
