Old 08-24-2021, 07:37 AM   #21
Liked 10,820 Times in 2,249 Posts
Default Re: Micro Welding of bearing shell to rod housing bore
The caps have dowels and the mating surface looks perfect. The upper shell is always not as tight as the cap shell in its bore.
Is there a certain finish that the bore needs to “hold” the bearings?
Old 08-24-2021, 08:18 AM   #22
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I've been reading this thread and wondered why no one mentioned detonation as being a possible issue.
It can show up in rod bearings....
Usually the shells just fall out....and might have some odd looking wear marks....
Rich Biebel
S/C 1479
Stock 147R
Old 08-24-2021, 11:21 AM   #23
CMcAllister
Liked 920 Times in 259 Posts
If the problem didn't exist, and now it does, something happened. I've seen upper bearing shells beat up to the point they just fall out of the rod.
Fly poop on spark plugs? Fuel change? Verify timing and TDC marks? Try another known good timing light?
Just reaching here.
Old 08-24-2021, 11:29 AM   #24
Billy Nees
Just reaching here.
or cam change too!
Billy Nees 1188 STK, SS
Old 08-24-2021, 12:32 PM   #25
First noticed it when we started getting close to the 590 hp number. Damper is on TDC, fuel seems to make no difference c11, c12, c10, renegade 116. cam changed made no difference.
Old 08-24-2021, 02:00 PM   #26
Rich Biebel
If the engine is apart and obviously it is....
Look at the ring lands and the tops of the pistons for any oddball signs that usually indicate detonation. Pecker tracks on pistons, or on the sides of the pistons above the rings. Ring lands beat up....
If all is clean then you can rule it out....
It's not likely but I thought I'd throw it out there.
Rich Biebel
S/C 1479
Stock 147R
Old 08-24-2021, 02:08 PM   #27
Frank Castros
Liked 2,741 Times in 967 Posts
Just thinking out of the box, how old is the Harmonic Balancer?
Old 08-24-2021, 08:05 PM   #28
At least 6 to 8 years old. Last time it was down I had crank checked for balance it was ok
Old 08-25-2021, 08:38 AM   #29
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
What brand of balancer are you using?
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 08-25-2021, 09:46 AM   #30
Ralph A Powell
Liked 225 Times in 136 Posts
A good read on honing the big end of steel rods is in the SA Design Jenkins small block Chevy book I’d how he puts .002 shim stock the hens the rods round then removes it. The rod is now out of round but high rpm it stretch’s back round as I remember it’s when the rod does not have enough material at the parting line.
Ralph A Powell is online now   Reply With Quote
