#25 |
Liked 544 Times in 213 Posts
If the engine is apart and obviously it is....
Look at the ring lands and the tops of the pistons for any oddball signs that usually indicate detonation. Pecker tracks on pistons, or on the sides of the pistons above the rings. Ring lands beat up.... If all is clean then you can rule it out.... It's not likely but I thought I'd throw it out there.
