Old 07-26-2021, 06:46 PM   #31
F677
F677's Avatar
Liked 21 Times in 6 Posts
Default Re: Moving from bracket to Stock Eliminator
Frank,
That's the all BS aside shot I like. I admit, I know I'm coming in as the bracket racer. My combo will not be easy, or likely to be 1 under. If it won't run .5 under I'll tear it apart and try again. Hoping for .8 to be honest. This is my "dip my toe in" start to big kid racing to see if it suits me. If it does, a more favorable (Ford) combo will follow. I hope to get to know you all soon, and you'll see that I'm no rub. If I'm in, I'm in, and I won't worry too much about the ladder.
Devin Froud
Div. 6
Roy Wa
F677 is offline   Reply With Quote
Old 07-26-2021, 10:52 PM   #32
fordteacherguy
Liked 160 Times in 51 Posts
Devin,
Looking over the 67 289 4v combo it has some good traits, +11:1 compression, heads are ok...typical small valve SBF head...making the Autolite 4300 4v work might be a challenge..small float bowl...there was a reason we called them toilet bowls in the.day...bone up on that particular carb tuning. Not a lot of stuff for that carb out there. Don't see it being a killer, but if you are determined...it looks like it could do the index...wish it had a better carb though...
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 07-27-2021, 07:29 AM   #33
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
Originally Posted by fordteacherguy View Post
Devin,
Devin,
You may be better off running that car in super stock with that engine, you can run the replacement aluminum head, and it will be fine with a 9" tire and a caltrac. Whether you run stock or super stock, Vern Buchanan would be the person to talk to about doing the carb.
Good luck with the project
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 07-27-2021, 02:35 PM   #34
Jim Caughlin
Liked 806 Times in 246 Posts
Doesn't it make more sense to convert the car to a '68 and run the holley carb 302 combination?
One other thing, if you want to be taken seriously, might want to post your real name.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 07-27-2021, 02:37 PM   #35
Jim Caughlin
Jim Caughlin
SS 6019
Oh sorry, just notice you did actually post your name.
Old 07-27-2021, 03:24 PM   #36
Liked 10,939 Times in 2,259 Posts
It might be advantages to read and understand all of the AHFS.
Old 07-27-2021, 05:08 PM   #37
Billy Nees
Yeeeeeeeaaaaaaaaaah, hey Larry, the next time that we speak, would you please explain it to me? Do ya think we'll live long enough?
Billy Nees 1188 STK, SS
Old 07-28-2021, 04:46 AM   #38
F677
F677's Avatar
Jim Caughlin
SS 6019
This is one area I am curious about. How tight are the regulations on proper body trim? A 68 has very different trim on the quarter panels and side marker lights all the way around. Are all proper hood, trunk, and side emblems required? The 68 302 setup would be a lot easier to work with.
Devin Froud
Div. 6
Roy Wa
Old 07-28-2021, 04:53 AM   #39
F677
F677's Avatar
Originally Posted by 1347 View Post
Devin,
It may be a better setup, but for now it's not the right time. If running divisional/national events works well for my family and I over the next couple years, be sure that I will build another bucket that will can go chasing ET records. This is my walk before I run entry to playing with you folks.
Devin Froud
Div. 6
Roy Wa
Old 07-28-2021, 06:44 AM   #40
1347
1347's Avatar
I am wondering why you think the 302 combo would be a better combo to work with?
You can only run the Holley carb if you run the car as a Mercury in GT super stock. The Holley was only avaliable on the Comets and Cougars. You would need to run the same carb as the 67 mustang combo but with 18 more hp, a little hard to overcome being the same engine except for 13 cubic inches.
The rules state that the car must appear as a 68. So it is suppose to have all the features as a 68 such as trim, marker lights, emblems and anything else that was changed from 67 to 68. Enforcement will be up to your division tech crew, and although it has become more lax lately, I would hate to be told I can't run my car after all the effort spent of building a car and showing up at a race.
Duane Hoven
1342 SS/GT
