Old 05-24-2021, 06:54 PM   #3
Jeff Niceswanger
Liked 1,072 Times in 379 Posts
Default Re: EFI Question
Originally Posted by Kdw1403 View Post
Fast XFI 2.0. I’m in alpha N mode. What all is involved and how hard is it to switch to speed density mode.
You would have to build an entire new map. Someone that knew what they were doing could take your WOT #'s, your idle numbers ( lbs. of fuel) and build a basic map, or if they already had one built for other customers cars very similar, use theirs and slightly modify it to fit your engine. Either way some tuning will be mandatory to get you going. But there is no plug and play between the two. The Alfa uses 0-100 % throttle to make its changes, the SD uses your MAP ( Manifold Air Pressure) to do the same thing.
I agree, if what you have runs good on Alfa, leave it alone.
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
