Old 05-24-2021, 01:30 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default EFI Question
Fast XFI 2.0. I’m in alpha N mode. What all is involved and how hard is it to switch to speed density mode.
Kdw1403 is offline   Reply With Quote
Old 05-24-2021, 01:48 PM   #2
KRatcliff
Liked 534 Times in 143 Posts
Default Re: EFI Question
I wouldn't make the switch, but that is just me.
KRatcliff is offline   Reply With Quote
Old 05-24-2021, 06:54 PM   #3
Jeff Niceswanger
Liked 1,072 Times in 379 Posts
You would have to build an entire new map. Someone that knew what they were doing could take your WOT #'s, your idle numbers ( lbs. of fuel) and build a basic map, or if they already had one built for other customers cars very similar, use theirs and slightly modify it to fit your engine. Either way some tuning will be mandatory to get you going. But there is no plug and play between the two. The Alfa uses 0-100 % throttle to make its changes, the SD uses your MAP ( Manifold Air Pressure) to do the same thing.
I agree, if what you have runs good on Alfa, leave it alone.
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
