Liked 627 Times in 156 Posts
Ok Paul I’ll bite, why not... did the culprit bolt before a request could be made? Was he there for eliminations or just took the trophy and ran?
Pete Lanciers PAL Automotive Racing Stock 7801 |
Liked 584 Times in 94 Posts
The engine was still sealed from a teardown last fall ..... Maybe someone can highlight us as to why he was removed from the ladder...?
Additionally, FYI , he was torn down (again) at Gainesville.
Also, he wasn't removed from the ladder, he was a no show. ( probably because his engine was completely apart ...)
Liked 1,344 Times in 410 Posts
I take it you were there Jim watching these tear downs. Hard to believe a stock bore production engine can seal up that well to make near 600hp. If not more! He goes .325 green and catches a second under competitor by the 660' is amazing all in its own. He has plenty left after coasting from the 1100' mark for all the F,G and still H cars now even at 322hp. Might need a better reaction though. That's what happens when you show that kinda performance. You bring extra gaskets.
Paul Haszlauer |
#6 | |
Liked 239 Times in 90 Posts
I have said this before. I was the one who got the piston approved which happened the last few days of Jan 2021. The only thing available before that time (The record set in Nov 2020) had to be a OEM piston. Chrysler doesn't make an oversized piston. You can buy an oversized piston from other vendors but that isn't approved. That is why I worked with Diamond and NHRA to get it excepted. It took a while. Is it stock bore, Left and right offset piston with a press on pin like stock OEM? If so it is good to go or does he claim stock piston and it isn't?
#8 | |
Liked 132 Times in 27 Posts
