Liked 1,344 Times in 410 Posts
I take it you were there Jim watching these tear downs. Hard to believe a stock bore production engine can seal up that well to make near 600hp. If not more! He goes .325 green and catches a second under competitor by the 660' is amazing all in its own. He has plenty left after coasting from the 1100' mark for all the F,G and still H cars now even at 322hp. Might need a better reaction though. That's what happens when you show that kinda performance. You bring extra gaskets.
Paul Haszlauer |
#2 | |
Liked 239 Times in 90 Posts
I have said this before. I was the one who got the piston approved which happened the last few days of Jan 2021. The only thing available before that time (The record set in Nov 2020) had to be a OEM piston. Chrysler doesn't make an oversized piston. You can buy an oversized piston from other vendors but that isn't approved. That is why I worked with Diamond and NHRA to get it excepted. It took a while. Is it stock bore, Left and right offset piston with a press on pin like stock OEM? If so it is good to go or does he claim stock piston and it isn't?
Liked 72 Times in 36 Posts
If the car can run that fast it might be in the wrong class to start with. I think the car with the extra 22HP. only needs to add 92 Lbs. to move to G/SA or remove 69 Lbs. and move up to F/SA. This is from the 3620 Lbs. at 300 HP. that was the Min. weight at the 2021 Baby Gators for that car combination in H/SA. Kenney Kelley
Liked 239 Times in 94 Posts
The 5.7 in a 2009 Challenger is rated by the factory at 370hp Net. It goes up from there for later ones. So why was it set at 300.... Payola?
Liked 279 Times in 68 Posts
That combination is so soft it’s ridiculous. Compare it to an LS1. How it got in the guide at
300 is a mystery. It’s still a killer deal at 322.
Greg Hill 4171 STK |
Liked 10,714 Times in 2,230 Posts
What did the DQ’s get? I hope it is fair to all involved especially the racers that got beat by the the rules breakers.
#8 | |
Liked 132 Times in 27 Posts
