#31 |
Liked 225 Times in 136 Posts
The Corvettes wheel base was to short for S/M!
#32 | |
Liked 1,597 Times in 583 Posts
I have seen copies of letters from NHRA allowing their use and even had a copy that I received from Alex Denysenko (RIP) of an NHRA letter allowing tubular arms on a late model Mustang. |
#33 |
With a stroke of a pen they basically killed previously approved aftermarket suspensions that NHRA had approved and had issued letters for their use.
#34 | |
Liked 311 Times in 175 Posts
#35 | |
Have you ever seen part numbers for SFI approved wheels on the accepted parts list? There are lots of parts that are accepted that are not on the list such as the Bump Steer ends that are allowed after many racers showed NHRA the danger and the tendency of the wheel of a car to steer itself after a wheelstand. One of the problems with NHRA is that they perceive any request for the allowance of new parts as a performance advantage. |
#36 |
And yet I have see late 90s - early 2000s Camaro & Firebird STOCKERS that had replaced the OE steering box and linkage with a Ford rack & pinion unit. No idea how that ever was allowed.
#37 |
Liked 239 Times in 114 Posts
1993 - 2002 Firebirds and Camaros had rack and pinion steering from the factory .
#38 |
Liked 1,001 Times in 276 Posts
Many items that have nothing to do with safety, are argued as a safety item. I remember not that long ago someone trying to say that certain engine components were not for performance, but for economical and safety reasons. That's probably why NHRA perceives it that way
Duane Hoven 1342 SS/GT |
#39 |
Liked 880 Times in 311 Posts
Because of the R&P on the Gen 4's there were several Gen3's built and approved by a prior Tech group. I had personal experience and argument about it a few years ago.
Adger Smith (Former SS) |
#40 | |
Many of the newer cars have stamped front crossmembers/cradles and lower control arms that are weak. The wheelstands will even weaken them more and if you notch them for big pans, they require lots of additional material to reinforce them. It was a war for a Super Stock racer to get NHRA to approve the allowance of aftermarket bump steer kits for safety reasons and it was not until he showed a Tech Division director a car that was at the verge to have a failure that the tech department changed their mind. |
