Old 10-14-2020, 07:21 PM   #1
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Door crash bars
Is it legal to remove them and any tips on how to on a 1973 Nova?
TIA
Already gave up.
Old 10-14-2020, 09:03 PM   #2
Default Re: Door crash bars
TIA
No, it's not legal. Nor is it legal to remove window regulators, etc.
However , seeing there's no tech, it's not enforced anymore.
PM me and I'll tell you how I would do it on a '73 Nova bracket car ;-)
Old 10-15-2020, 08:37 AM   #3
Devo
Liked 2 Times in 2 Posts
Not legal but on our '87 Grand Prix bracket car, I chopped off both ends at the welds with a cutoff wheel, (After cutting out most of the inner door panel to make room). It wasn't easy but damn, they sure are HEAVY!
dev0
Devo is offline   Reply With Quote
Old 10-15-2020, 09:05 AM   #4
nickh
nickh's Avatar
Liked 657 Times in 197 Posts
Mine were easy because we made sheet metal door panels, as Devo said you will be amazed how much they way. My Nova was a bracket car and weighed 2520 minus driver with sbc aluminum heads.
Old 10-15-2020, 09:25 AM   #5
Bob Shaw
Liked 318 Times in 62 Posts
I would never take the crash bar out of the driver's door.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 10-15-2020, 10:22 AM   #6
Devo
I take the left lane and run close to the wall !
...actually, my '66 nova never had crash bars, maybe we should require them.
Old 10-15-2020, 08:56 PM   #7
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Is that not part of what the side bar of the roll bar/cage is supposed to do? Yes I realize not required in slower cars, but it is recommended!
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 10-16-2020, 12:16 AM   #8
GTX JOHN
We race a couple slow class cars (N/SA up)
They all have NHRA legal rollbars and 5 pt. Harness.
You can be running 100 MPH and get hit by a 150 - 160 MPH Factory car
thru the top end!
When a fast car was 125 - 130 MPH = I did not worry like I do now!
John Irving
741 Stock
741 Super Stock
Old 10-16-2020, 09:39 AM   #9
Alex Polewik
Alex Polewik's Avatar
Liked 100 Times in 20 Posts
Not safety related but a 70 Cuda SS/DA car I owned had fiberglass crash bars installed to look like the originals. Pretty creative car with some factory help back in the 70's.
Alex Polewik is offline   Reply With Quote
Old 10-16-2020, 11:00 AM   #10
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
TIA
Already gave up.
I've done it several times over the years (before plasma cutters). It takes 2 people, one that is good with a torch and a good helper. Fill a large cooler with ice and water, soak a large heavy bath towel in the cooler, wet the inside of the door. Fold and place the cold soaked towel on the outside of the door skin in the area of the cut, quickly cut from the top down with a torch. If it doesn't completely cut on the first attempt, move to the other door. DO NOT COOL THE WARM PANEL IF FIRST ATTEMPT FAILS, the door may shrink and distort panel. Be patient and restart procedure once the door cools naturally. Try this on a junk door first to see how things work, if you can. The object is to keep the door skin COLD while cutting. I have done this on several finished cars to help trim some weight, to compensate for the owners "Second Cheeseburger Syndrome". Hope this Successful Method helps...MB.
MAURICE BLENDHEIM is offline   Reply With Quote
