Liked 10,712 Times in 2,230 Posts
I thought it takes heat to help atomized the fuel so the smaller particles will burn more completely. Will cooling the fuel slow the process and result in larger particles in the cylinder. Is it less important in a FI than a carbed engine.
Liked 1,583 Times in 582 Posts
Increased fuel temperature makes the fuel less dense and reduces the amount of oxygen, many times turning it into vapor. Cooling the fuel, increases its density and the oxygen molecules stay closer when compared to hot fuel and reduces vaporization. It also reduces the vaporization rate of the fuel. That is why warm or hot fuel causes vapor lock.
Liked 973 Times in 195 Posts
Saw a racer drop a chunk in his fuel cell before a class run and it erupted like a small volcano.LOL
Thanks
