Old 09-04-2020, 12:18 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: Trailer tire issues
This 15 inch trailer tire issue has been beaten to death. The load range on the tire is the important part. Load range d will not work. Load range e is much better and I had no trouble with the set of load range I just took off because of age. But there are now load range F 15 trailer tires that are really beefy and heavy and should cure these problems. I probably went thru 20 load range d’s, Goodyear even warranted some. F is the way to go. When see one you see what I’m talking about!
Painter is offline   Reply With Quote
