Old 08-29-2020, 10:18 AM   #21
Liked 10,941 Times in 2,259 Posts
Default Re: "Live" from Beech Bend 2020 divisional
If there is anyone here that knows anything about air conditioners on motorhomes, could you come by and see us? Brand new and it stopped cooling! Thanks!!
Old 08-29-2020, 10:39 AM   #22
Rod Greene
Liked 242 Times in 81 Posts
Larry did it freeze up? The humidity has iced up the ac on my truck a few times I turn it off let it thaw and then it works fine.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 08-29-2020, 11:06 AM   #23
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Larry we had the same problem with a new Renagade at
Columbus. Our problem is with the power protection module.
It would switch back to battery inventor source.The generator
Would still be running. The AC will not run on battery source.
Shut down the generator and start back up.
We would have a power fault on the control center also.
We have new protection module to install but haven't done it
Let.
Hope this will give you a temp fix on your problem
David
Willyracer is offline   Reply With Quote
Old 08-29-2020, 11:57 AM   #24
Dan Walcott
Liked 92 Times in 26 Posts
Did the cars in Stock and Super Stock that were " DNQ" get OK'd to compete? or is it as the ladder is , after 1st qualifier?
Dan Walcott is offline   Reply With Quote
Old 08-29-2020, 12:48 PM   #25
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
Someone post the ladder please? No live timing for D3, bummer....but thanks to Warren and Unk (and of course this weekend’s primary sponsor, the Bo Butner auto group).
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-29-2020, 01:36 PM   #26
Mike Pearson
Mike Pearson's Avatar
Liked 1,981 Times in 597 Posts
Is it still running or stopped all together. Could be the run capacitor for the compressor gone bad.
Mike Pearson 2485 SS
Old 08-29-2020, 01:46 PM   #27
Warren Evans
Warren Evans's Avatar
Liked 1,598 Times in 190 Posts
Thanks for the shout out but it is my "Executive Producer" Jay Hullinger taking care of dragracer.tv this weekend while I'm at home for my daughter's wedding this weekend.
Warren Evans is offline   Reply With Quote
Old 08-29-2020, 03:18 PM   #28
BG56
Liked 301 Times in 113 Posts
Telecast just froze up after Super Street, been fuzzy all day. Maybe the weather, anyone else having trouble?
Old 08-29-2020, 03:20 PM   #29
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
yes, same thing
Old 08-29-2020, 03:21 PM   #30
Dan Walcott
same thing here, my two best classes, stock & super stock , locked up
