#21 |
Liked 10,929 Times in 2,258 Posts
If there is anyone here that knows anything about air conditioners on motorhomes, could you come by and see us? Brand new and it stopped cooling! Thanks!!
#22 |
Liked 242 Times in 81 Posts
Larry did it freeze up? The humidity has iced up the ac on my truck a few times I turn it off let it thaw and then it works fine.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
#23 | |
Liked 57 Times in 24 Posts
Columbus. Our problem is with the power protection module. It would switch back to battery inventor source.The generator Would still be running. The AC will not run on battery source. Shut down the generator and start back up. We would have a power fault on the control center also. We have new protection module to install but haven't done it Let. Hope this will give you a temp fix on your problem David |
#24 |
Liked 92 Times in 26 Posts
Did the cars in Stock and Super Stock that were " DNQ" get OK'd to compete? or is it as the ladder is , after 1st qualifier?
#25 |
Liked 3,232 Times in 983 Posts
Someone post the ladder please? No live timing for D3, bummer....but thanks to Warren and Unk (and of course this weekend’s primary sponsor, the Bo Butner auto group).
#26 |
Liked 1,967 Times in 595 Posts
Is it still running or stopped all together. Could be the run capacitor for the compressor gone bad.
Mike Pearson 2485 SS |
#27 |
Liked 1,598 Times in 190 Posts
Thanks for the shout out but it is my "Executive Producer" Jay Hullinger taking care of dragracer.tv this weekend while I'm at home for my daughter's wedding this weekend.
#28 |
Liked 301 Times in 113 Posts
Telecast just froze up after Super Street, been fuzzy all day. Maybe the weather, anyone else having trouble?
#29 |
Liked 484 Times in 160 Posts
yes, same thing
#30 |
same thing here, my two best classes, stock & super stock , locked up
