Old 01-10-2020, 08:37 PM   #191
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Nova stocker project.
Now lets see some data
Old 01-10-2020, 08:41 PM   #192
Alan Nyhus
Liked 799 Times in 236 Posts
Be a couple days before we're at that point. -Al
"That'll never work....."
Old 01-10-2020, 09:22 PM   #193
HP HUNTER
Whats a good flow number for a 1.940 fuelie stocker head @ .400 lift? Anyone.......
Old 02-06-2020, 10:35 AM   #194
Alan Nyhus
Got the cam broken in and valve springs changed. Made some preliminary pulls and moved the cam around. We'll get back to it after the Phoenix National event. -Al
Old 02-06-2020, 01:17 PM   #195
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Tease......
Old 02-06-2020, 03:00 PM   #196
Dissident
Liked 73 Times in 36 Posts
Alan and others,
Can't tell from the pic, but if the odd number side plug wires are similarly bunched......it would be better to be sure that 5 and 7 DO NOT run parallel and bunched together (should be separated at least a couple of inches). An odd thing called inductive coupling occurs and can encourage cross firing and you would not hear it but power would suffer a bit. Yeah, I know that is not the kind of stuff one hears on forums and such unless it is underlined with "some guy said" but it is a technical truth that is worthwhile to know. Where did you dyno test your engine? They should have known this item from their own testing and trouble shooting.
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 02-06-2020, 05:42 PM   #197
Alan Nyhus
Originally Posted by Dissident View Post
Alan and others, Can't tell from the pic, but if the odd number side plug wires are similarly bunched......it would be better to be sure that 5 and 7 DO NOT run parallel and bunched together (should be separated at least a couple of inches). An odd thing called inductive coupling occurs and can encourage cross firing and you would not hear it but power would suffer a bit.
This will be a good time to test that. -Al
Old 03-08-2020, 01:17 PM   #198
Alan Nyhus
Finished up by testing four different fuels. Time for it to go in the car and get ready for the season.
I can't thank Bob Sherwood enough. It's his dyno that I'm fortunate to test on. His experience in not only dyno operation but data interpretation have been invaluable. Bob is truly one of the good guys.
Thank you, Bob!
Old 03-12-2020, 09:27 PM   #199
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
NICE headers. Bet those were spendy.
Dave Noll, EF/S ,?/SA 6526
Old 03-13-2020, 07:50 AM   #200
Alan Nyhus
Cal Elston does beautiful work. Smart, smart guy. -Al
