#11 |
Liked 748 Times in 137 Posts
Where in the rulebook does it state that a converter dump valve is illegal?
#12 |
Liked 239 Times in 90 Posts
#13 |
Liked 61 Times in 22 Posts
Lol....the word innovation is sure getting used a lot in place of cheating.
#14 |
I showed you the email of the rules we were told to play by, so yes sir....your stuff needs to get bounced in my eyes. I adhere to the rules as does my engine builder. We have to worry about winning races and therefore we need to worry about being legal in every division, not just 1 or 7.
#15 |
And since we are at it.
Gas Ported pistons Aftermarkets Cranks Honda Journals Chamber Mods It all started in the same place, cheating is not innovation......its cheating no matter what his minions call it. And as far as Jeff, hell yeah he did the right thing. He has customers spending 10s of thousands trying to run with people that hasn't ever been able to follow a rulebook. It came right out of your own mouth that you wouldn't ask permission.....well that sir doesn't make it right and it damn sure doesn't give you all the right to stop your feet when you get called out on it. Last edited by Joey Bohannon; 12-28-2019 at 03:32 PM. |
#16 |
So with that logic, and just keeping it related to the transmission: We all have to remove our straight-cut/different than OEM ratio gearsets, take out our roller bearings and go back to bushings, remove our low volume front pump and put a stock one back on, make sure we run the correct number of clutches and steels that the OEM trans had, remove the aluminum drums and put the cast iron OEM ones back in etc etc etc ?
#17 | |
Liked 1,939 Times in 583 Posts
Mike Pearson 2485 SS |
#18 | |
#19 |
I take that back, th400 and PG. I would love to have one in my stocker. Make the converter loose at the hit so it will 60' and then tighten it up down track to improve ET
#20 | |
Liked 124 Times in 39 Posts
Jeff has been caught cheating numerous times....delay boxes, bigger cic than claiming, so your point is.....well.....laughable!
Sean Cour T6066 ladle |
