Liked 231 Times in 107 Posts
Hughe has a pretty good tutorial on Youtube. Also called a Converter dump valve.
Liked 61 Times in 22 Posts
Actually Mr. Cour, this is another one of those things we have been told not to do.....just like the head modifications I showed you the emails of. Like I said.....different rules for different divisions.
I can't knowingly do something that is it illegal and expect to be able to throw a fit and get away with it. That's just not the way I roll. Last edited by Joey Bohannon; 12-28-2019 at 07:01 AM. |
#3 | |
Liked 124 Times in 39 Posts
Joey, so colluding with a sanctioning body, to oust a mod that has been stamped legal for years, just to feel good about your inability to innovate, is suppose to make you feel good? Strange way of doing business, don't you think?
Sean Cour T6066 ladle |
Liked 167 Times in 81 Posts
I don't see much need for it on most Super Stock cars.
Liked 748 Times in 137 Posts
Where in the rulebook does it state that a converter dump valve is illegal?
Liked 239 Times in 90 Posts
Lol....the word innovation is sure getting used a lot in place of cheating.
So with that logic, and just keeping it related to the transmission: We all have to remove our straight-cut/different than OEM ratio gearsets, take out our roller bearings and go back to bushings, remove our low volume front pump and put a stock one back on, make sure we run the correct number of clutches and steels that the OEM trans had, remove the aluminum drums and put the cast iron OEM ones back in etc etc etc ?
And since we are at it.
Gas Ported pistons Aftermarkets Cranks Honda Journals Chamber Mods It all started in the same place, cheating is not innovation......its cheating no matter what his minions call it. And as far as Jeff, hell yeah he did the right thing. He has customers spending 10s of thousands trying to run with people that hasn't ever been able to follow a rulebook. It came right out of your own mouth that you wouldn't ask permission.....well that sir doesn't make it right and it damn sure doesn't give you all the right to stop your feet when you get called out on it. Last edited by Joey Bohannon; 12-28-2019 at 03:32 PM. |
#10 | |
Jeff has been caught cheating numerous times....delay boxes, bigger cic than claiming, so your point is.....well.....laughable!
