Old 06-27-2019, 09:36 AM   #1
Billy Nees
Liked 7,925 Times in 1,760 Posts
Default Re: Stock hood configuration clarification
Originally Posted by e vassar View Post
Well,how much ET is a hood latch worth?
Probably not a lot........... unless you put it with your missing front bumper brackets, the aluminum radiator, master cylinder, water pump, light-weight aftermarket brakes (safety first!), chemically enhanced (or aftermarket) front fenders and hood (minus the latch), oh and your plastic dummy battery in front to go with the real, relocated battery in the trunk. And I almost forgot the super lite front wheels (with the SFI tags) that crack when you turn corners.
Probably an easy couple of hundred pounds that you can stuff in the trunk. Make sure it's legally mounted! Safety first!!!
Billy Nees 1188 STK, SS
Old 06-30-2019, 12:21 AM   #2
e vassar
Liked 281 Times in 110 Posts
Thanks for the comprehensive list
I'm going to start with my front bumper brackets...hope it doesn't fall off.
LOL
