Old 06-02-2019, 08:10 AM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 985 Times in 314 Posts
Default Re: H-I-J '76 Nova re-fit.
Check out the Dart shp block.
Old 06-02-2019, 09:41 AM   #2
Liked 11,032 Times in 2,267 Posts
Check the new blocks before you send them off. The main bearing housing bore might surprise you. "If it ain't broke don't fix it"
Old 06-02-2019, 10:27 AM   #3
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: H-I-J '76 Nova re-fit.
I like the Dart block I bought for my Chevelle.It's quite thick, rather heavy, but nothing I could do to it would hurt it,barring a broken rod or something. You've had the crank checked and done so many times it probably isn't the problem, check and use i again if it's a steel crank. The production GM 350 blocks tended to be thin,sometimes you go through a lot of them before you find one with no core shift or thin places where it needs to be thick.It sounds like something is structurally weak in the block you have been using, something obviously moves when you torque it down if the results keep changing. Einstein said that the definition of insanity is when you try the same thing over and over expecting different results. This block sounds like you constantly try the right thing the same way each time, and different results keep popping up. Something is moving around and giving you different results each time. It could be a hidden crack, a soon to be crack, or some type of metallurgical flaw.It could result in disaster. Also, 4 speed cars are harder on a lot of things, the Dart block might be what's required to keep the cylinders round, the decks flat,and the main bearing line bores straight. The NHRA approved parts list has the correct part number for that block, and Summit ships them right to your porch.
Old 06-02-2019, 10:41 AM   #4
Greg Reimer 7376
The NHRA legal replacement part number for a 4 inch bore SBC with a 2 piece rear main seal is 31161111. Summit shows it in their catalog for $1718.26 on page 124. That's the March-April catalog.
Old 06-02-2019, 11:22 AM   #5
Nmbr1GMfan
That will for sure be my next one.
Todd Greene
Old 06-02-2019, 04:08 PM   #6
Nmbr1GMfan
Today we pulled the redneck A/C from the rafters for what will surely be another hot summer. Started pulling Racepak bits out of the boxes and found a spot for the logger just for something to do. I'll update on the block situation tomorrow, if I can pick one up local I'll have a plan in place pretty quick.
Todd Greene
Old 06-03-2019, 12:22 AM   #7
Jody Lang
Liked 92 Times in 29 Posts
So was the #3 main cap broke?
Jody Lang is offline   Reply With Quote
Old 06-02-2019, 11:19 AM   #8
Nmbr1GMfan
Everything is absolutely correct, especially this.
Todd Greene
